Author Topic: Denon SC6000 RJ45 Link socket  (Read 182 times)
Offline AudiorepairTopic starter
« on: November 03, 2024, 05:11:30 pm »
OK, so I need to replace the RJ45 link socket on a Denon SC6000.
After searching Mouser, I came up with this which is an identical size and footprint.
https://www.mouser.co.uk/ProductDetail/960-TMJ0162GDNL
Only it doesn't work (and the right yellow LED is the opposite polarity of the original)
A bit of Googling the data sheet shows the pinouts are clearly not compatible with the Denon configuration you can see in the photo of the PCB.
https://www.taoglas.com/datasheets/TMJ0162GDNL.pdf.  Section 4.1 shows the pinout.
The Denon has I presume 4 pairs of data lines.
Now this is when I realise that I don't have a clue about any of this, the RJ45 is not the Universal connector I presumed it was, and I'm not even that sure what T10/100 base blah blah is either.
So the question is, what should I actually be looking for in my Mouser (etc) search parameters?
What are Denon doing  here?
« Last Edit: November 03, 2024, 05:14:20 pm by Audiorepair »
Re: Denon SC6000 RJ45 Link socket
« Reply #1 on: November 04, 2024, 09:59:27 am »
So I've managed to find almost what I'm looking for now.
This datasheet has circuits C & D which appear to be very similar with what I pulled from the Denon.
https://www.mouser.co.uk/datasheet/2/706/fastjack_gigabit-520265.pdf
They show Pin one as VCC, though in the Denon it is connected to ground along with pin 10.
