Author Topic: Desktop PSU dead  (Read 3321 times)
Offline drummerdimitriTopic starter
  • Country: lb
Desktop PSU dead
« on: March 14, 2020, 06:33:53 pm »
My PC decided not to turn on today for some reason.
I took it out of the case and tried the paperclip trick to try to turn it on but no luck.
I remember having had the same issue in the past and it turned out to be a bad capacitor (bulging on top).
My guess was the same component needed replacement but unforturnalty its capacitance is measuring well.
Is there anything else to measure in a capacitor to determine if it's in good condition or needs replacing?
There appears to be no obvious sign of damage on the board so I'm not sure where to even start?
Mind you this is a very old PSU (15 years old) so maybe it's time it hit the bucket. These days they're at least 10 percent more efficient.
Offline vidarr
  • Country: br
Re: Desktop PSU dead
« Reply #1 on: March 14, 2020, 06:59:01 pm »
I have retired many PSU's. Being that old, you really should get a new one. Most of the decent brands EVGA, Thermaltake, have seven and ten year warranties now. I just burned out two PSU's recently and easily used the warranty to replace them.
Did you check the fuse?
Online wraper
  • Country: lv
« Reply #2 on: March 14, 2020, 07:04:55 pm »
More like most overpriced brands. FWIW you need to look at particular model. Under single brand you often can find a very good PSU line made by one OEM, and not so good made by another OEM.
Online wraper
  • Country: lv
« Reply #3 on: March 14, 2020, 07:05:57 pm »
Not very likely it's simply a bad capacitor. First of all you need to check if there is 5V standby voltage.
  • Country: lb
« Reply #4 on: March 14, 2020, 07:14:27 pm »
I did check the fuse and it's in working order.
I would much rather try fixing the unit before giving up on it entirely...
  • Country: lb
« Reply #5 on: March 14, 2020, 07:15:52 pm »
How do I do that? Do I keep the green and black wire shorted and test for a 5V signal on the red and black wires?
Online wraper
  • Country: lv
« Reply #6 on: March 14, 2020, 07:34:37 pm »
5V stand by must be always present as long as PSU is connected to mains. It's violet wire. How do you think shorting green wire to GND even works?
  • Country: lb
« Reply #7 on: March 14, 2020, 10:33:53 pm »
I found a large diode with SR 540 written on it.
Seems to be a schottky diode and upon testing it with my DMM, it has a voltage drop of 0.0003 V or so in both directions.
Could this be the culprit?
Offline Mr. Scram
  • Display aficionado
« Reply #8 on: March 14, 2020, 10:42:50 pm »
It's probably best to get a new PSU. Modern ones are more efficient and old power supplies can cause all kinds of intermittent trouble. Cheaper units have the potential of damaging other components too.
Online wraper
  • Country: lv
« Reply #9 on: March 14, 2020, 10:45:52 pm »
It's dead if you measure it out of circuit. If in circuit, there is also a little chance that something on power rail (after diode) shorts it to ground. SR540 is 5A 40V schottky diode.
« Last Edit: March 14, 2020, 10:48:44 pm by wraper »
  • Country: lb
« Reply #10 on: March 14, 2020, 11:16:52 pm »
Yes I always test components out of the circuit to be sure.
My local electronic parts dealer has only the SR 560 in stock which is 60V, 5A. Will this work?
« Last Edit: March 14, 2020, 11:28:25 pm by drummerdimitri »
Offline vidarr
  • Country: br
« Reply #11 on: March 14, 2020, 11:45:47 pm »
THIS.
Offline xavier60
« Reply #12 on: March 15, 2020, 12:00:58 am »
Yes, the higher the voltage rating the better. If  that really is the rectifier for the STB5V, the reverse voltage can be surprisingly high.
It will be close to a small transformer if it is.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline vidarr
  • Country: br
« Reply #13 on: March 15, 2020, 12:02:28 am »
[/quote]
One man's overpriced brand, is another man's pocket change. There is a reason to buy a good brand -- they have a reputation of being good. Some people, like me, like the ease of mind knowing if it goes bad, there is a ten year warranty. I change out PSU's before they even get that old. When you maintain hundreds of PCs, this is a HUGE Advantage/Plus. I practice this not only with corporate computers, but with my own, personal PC's too.
As for the model, it is up to the OP, to pick out the model. He didn't even provide what CPU he is using -- nothing at all about his computer. You cannot properly pick out a model without knowing this. That is for him to decide too based on his budget. If he provides specs on his rig, I would gladly suggest a model.
Also, as another poster wrote (in other words), feeding "bad" electricity into his computer is going to take a toll on other components.  :)
Online wraper
  • Country: lv
« Reply #14 on: March 15, 2020, 12:34:05 am »
There is nothing magical about EVGA. http://www.orionpsudb.com/evga you are simply buying HEC, FSP, Super Flower, Seasonic. Which you can easily buy with different label for less. As of their quality, I have repaired some EVGA GTX 1080 SC, and they are the worst 1080 I've seen. They even provided updated bios and free thermal pads to fix VRM and RAM overheating problem. https://www.evga.com/thermalmod/
EDIT: BTW they have plenty of products with 1 year warranty. And when you buy something with 10 year warranty, you are seriously overpaying. You often can buy PSU with the same internals and comparable warranty for 30%+ less.
« Last Edit: March 16, 2020, 11:12:20 am by wraper »
Offline m3vuv
« Reply #15 on: March 15, 2020, 10:59:59 am »
has no one mentioned checking the caps esr?
Offline Circlotron
« Reply #16 on: March 15, 2020, 12:03:36 pm »
Yes.
I have had one of the diodes on the +12V rail go shorted and it stopped the whole supply from starting up.
The following users thanked this post: drummerdimitri
  • Country: lb
« Reply #17 on: March 15, 2020, 02:27:43 pm »
How do I do this? Do I need an LCR meter?
Offline Rasz
    • My random blog.
« Reply #18 on: March 16, 2020, 05:59:06 am »
dont bother, replacing caps instead of measuring is cheaper and faster
after desoldering the diode did you check if this spot is shorted?
first thing first would be checking if the controller is being powered at all, picture of the pcb would help to identify what chip is running the show, tl494? something modern? how is it powered?
Where was the dead diode?
is active PFC working(charged high voltage caps)? is standby supply working?
older EEs dont like fixing power supplies, $20 here $50 there means nothing to them, they got fat and lazy, like dealer car mechanic - replace and forget  :box:
Offline hesam.moshiri
    • MyVanitar
« Reply #19 on: March 16, 2020, 09:32:10 am »
The problem also could be from the controller chip, I assume it is TL494, especially if you don't have any output voltage
Online wraper
  • Country: lv
« Reply #20 on: March 16, 2020, 10:56:20 am »
Frankly it is starting bugging me how people throw some random guesses instead of helping troubleshooting. OP already found faulty diode, and I'm assuming in standby supply rectifier according to part number. TL494 has nothing to do with standby supply. And if it is somewhat decent PSU, not very likely there is TL494. Not that they fail often to begin with.
Online wraper
  • Country: lv
« Reply #21 on: March 16, 2020, 11:02:02 am »
Should work fine. The only downside is that it has sightly higher forward voltage. Also you don't necessarily need diode from SR series.
  • Country: lb
« Reply #22 on: March 16, 2020, 10:22:13 pm »
I found a diode labeled IN5844 in my parts bin.
Looks like it's also rated at 40V 5A so should I replace the old one with this diode?
Offline Circlotron
« Reply #23 on: March 16, 2020, 10:45:06 pm »
^^ Looks okay at first glance.
Online wraper
  • Country: lv
« Reply #24 on: March 16, 2020, 10:52:39 pm »
Perfect substitute.
