Author Topic: Looking for a small PCB-mount microswitch with a long stem  (Read 517 times)
Offline PhaseseekerTopic starter
« on: April 27, 2024, 03:16:47 pm »
I'm trying to fix an old laserdisc player from Pioneer, and the microswitches that are used modeswitch don't work properly (tried flooding the inside with contact cleaner, no luck); the exact parts (Pioneer DSG1015) are basically unobtanium in Europe (unless one wants to spend 50€ on a switch...), so I'm trying to figure out if I can replace them with a modern part. The problem is that the original switches are
a) very small
b) they have a fairly long "stem", with a pretty long travel and a very weak spring, so I can't just put a tact switch there.
See the attached picture. Any ideas on where to look for a part I can adapt?
Online tooki
Re: Looking for a small PCB-mount microswitch with a long stem
« Reply #1 on: April 27, 2024, 07:04:15 pm »
You’re not finding them because these are not called microswitches. Panasonic calls them “detector switches”, Omron “detection switches”. Look at https://www.digikey.com/short/hv315jf2
« Reply #2 on: April 28, 2024, 10:19:41 am »
That's exactly what I was looking for. Thanks!
Online tooki
« Reply #3 on: April 29, 2024, 06:46:23 pm »
Glad to help! I know how it often depends on knowing the “magic word” to google for. (Or being so familiar with Digikey’s category tree to be able to identify the right word in a list! ;) ) Good luck with your repair! :)
Offline inse
« Reply #4 on: April 30, 2024, 04:47:34 am »
If you adapt an other switch here, the challenge will be to precisely and reliably detect the correct position…
