Leave in white vinegar for an hour or so, hopefully it'll remove all those deposits and corrosion.
(Clean all that flux first!)
To remove it, you'll need a hot air rework station, definitely not something you can do in a garage with few cheap tools.
A common 2KW heat gun might do it, but it will blast 800ºC heat, so you'll have to be extremely careful, preteating the entire board for 2-3 minutes to reduce warping and then blasting the main IC wih the heat.
Those old boards are not even close to today's FR4. They're junk, very delicate, they will delaminate very easily.
Too much heat for 2 seconds - popcorn! Blisters everywhere, if there were vias in the zone, now they're gone.
If it's a multilayer pcb, then you're really screwed!
And that IC package is a nightmare to work with, it's just too easy to damage the legs.
