Forget your "soft" iron and use a high profile 150W
hand GUN... usually just some brands available...
I'm currently using a desoldering gun that can provide up to 160W.
Combine that by flooding your spot with a
LOW MELT ALLOW ALLOY like
https://www.aliexpress.com/item/2Pcs-lot-MECHANIC-Lead-Free-Solder-Soldering-Wire-0-3-0-4-0-5-0-6/33016004971.html
Good enough for normal budget and in time results.
Admittedly, I am using lead-free solder as I'm really trying to transition away from leaded solder. I've had pretty good results with lead-free, though, if it's going to make a big difference I could use leaded solder for this (all the original joints will probably be leaded anyway).
Desoldering (if I got you right like vacuum ? ) just will not
cope with high thermal mass..
I am suggesting that hand GUN w/embed transformers..
they can cope w/high thermal mass fine.. 150W minimum
I am suggesting LOW MELT ALLOY BISMUTH based.
NOT LEAD FREEThey will form a final mass with lower melt point.
ALAS my experience w/lead free is just a crap.
They brittle and crack in particular just after being
excessive heated like this..
LEAD FREE is just garbage for serious repair.
I have checked the suggested BISMUTH and my opinion
is that you need to remove that later...
I always replace with leaded..
simple fast example..
https://www.aliexpress.com/item/1005002670551859.htmlI have an old school one very robust hand gun..
150W is piece of cake on the wire.
Paul
