Author Topic: SOLVED : dewalt battery powered radio - no power at board  (Read 1530 times)
Offline geoffagainTopic starter
« on: July 21, 2023, 09:00:04 am »
Hello, any clues on how to fault find this
Power board not outputting voltage to main board.
Seems like battery voltage comes in and runs through a battery discharge protection circuit triggering a P-Channel Mosfet NCE40P13S for output to main board.
Uses C3 pin on battery which I think is one of the cell voltages
Input from battery is 20V fully charged
Measuring with a fully charged battery finds battery voltage at the gate of the mosfet, nothing on the drain and full battery again on the source which doesn't seem right. Data sheet suggests a differential of -2.5v needed between the gate and source to switch.
The two diodes on the output of the mosfet seem to be ok.
Some of the solder points look balled - but compared to other boards ive seen this seems to be common or from factory?
Any tips on fault finding and understanding the way this circuit works please would be appreciated.
« Last Edit: July 27, 2023, 11:11:46 am by geoffagain »
Offline Jwillis
Re: dewalt battery powered radio - no power at board
« Reply #1 on: July 22, 2023, 02:44:13 am »
Whats the model of that Dewalt radio. Might get lucky and find a circuit diagram for it.
« Reply #2 on: July 22, 2023, 07:26:18 am »
DCR012 - haven't been able to find a schematic
looks to be battery discharge protection
Offline Jwillis
« Reply #3 on: July 22, 2023, 02:43:50 pm »
More likely includes battery charge controller . The  DCR012 is also a charger for 7.2V to 18V DEWALT battery packs when connected to mains AC.
« Reply #4 on: July 22, 2023, 03:45:02 pm »
I made a typo it’s dcr021
No ac on this device
This board handles battery input and outputs to main board via single connector
Offline nali
« Reply #5 on: July 22, 2023, 04:14:46 pm »
The PMOS needs a Vgs to switch as you say so it's probably OK. Try looking at the other end, U1 looks like it is probably a comparator so try tracing the components and checking around there.
Mind you, a replacement board is only ~£20 including VAT & postage, so may not be worth spending too much time on it...
https://www.sparepartsworld.co.uk/product/1004694-54
« Reply #6 on: July 22, 2023, 05:16:52 pm »
You make a good point, its a cheap enough board to replace but if I can get this one working for free then all the better.
Found a short on U1 between pin 2 and 3
Cleared it and re flowed the joints but still no joy, doesn't seem to have made a difference
Seems to have single cell voltage between pin 2 and pin 3
Pin 3 16.42V - from battery c3 pin
Pin 2 20.5v - from battery + pin
Pin 1 is outputting 18.67v with reference to battery negative
U1 is marked B8PW
« Reply #7 on: July 23, 2023, 11:52:16 am »
Ive had a go at drawing out the part of the circuit on the left hand side of the board
« Reply #8 on: July 26, 2023, 01:59:28 pm »
Triple posting here - but if anyone has any pointers for testing / fault finding this circuit be much appreciated
Offline nali
« Reply #9 on: July 26, 2023, 04:13:03 pm »
Assuming it is a voltage detector, I would expect the output of U1 to be either at it's Vdd or Vss pins not some halfway value. It may well be an open-drain output. What happens if you put a lowish value resistor say 1k between pins 1&2 (it may help to remove it first)
Oh, if you did have a short between pins 2&3 that would permanantly load the top battery cell via R2/R10 which isn't ideal although hopefully the battery charger/BMS can cope with it.
The following users thanked this post: geoffagain
« Reply #10 on: July 26, 2023, 04:39:26 pm »
Someone over on badcaps mentioned it looks like aS-80830CNMC a 3v voltage detector
looking up the datasheet
S-80830CNMC-B8P-T2
Series Seiko Instruments
SOT-23-5
Voltage detector IC
3.0V±2%, -Reset ODO
Nch open-drain output (Active Low)
So should be passing battery voltage - like you say not some halfway value
I can try adding a high value resistor between pin 1 and 2 - I'll report back.
Correct on loading the top battery cell, thankfully I've only used my batteries for testing this briefly and as theres no output from this board through the pmos should be drawing minimal current :)
« Reply #11 on: July 26, 2023, 08:02:49 pm »
Tried a 1k resistor between pin1 and pin2
passes battery voltage onwards but pmos still not turning on
voltage differential at the gate of the pmos with resistor is about -200mV
Offline nali
« Reply #12 on: July 26, 2023, 08:41:17 pm »
You'll need to be a bit more specific - what does "passes battery voltage onwards" mean?
Offline fzabkar
« Reply #14 on: July 26, 2023, 09:53:13 pm »
Sorry - yes essentially passes Vdd to output via 1k resistor - doesn’t seem to affect gate voltage at the pmos at the very end of the circuit, or at least not enough to turn it on and have an output at the output pins of the board. Measured differential at the gate of the pmos was about -200mV with the resistor added.
Offline fzabkar
« Reply #15 on: July 26, 2023, 11:25:03 pm »
In your diagram you are showing R15 as 01E, 9Mohm. Should that be 01E, 1Mohm?
https://kiloohm.info/eia96-resistor/01E
Are the "205" resistors actually "20S", in which case they would be 15.8 ohms?
https://kiloohm.info/eia96-resistor/20X
"88D" is 806K.
https://kiloohm.info/eia96-resistor/88D
« Reply #16 on: July 27, 2023, 08:14:44 am »
"88D" is 806K.
Well spotted! R15 is actually 0.986M ohm measured
Resistor values as measured in circuit >
J1 - 0 ohm
J2 - 0 ohm
J3 - 0 ohm
J4 - 0 ohm
J5 - 0 ohm
PCB number - SMD - value - measured
R2 - 101 - 100 ohms
R3 - 205 - 2M ohm - 1.953M ohm
R4 - 205 - 2M ohm - 1.875M ohm
R5 - 205 - 2M ohm - 0.674K ohm
R6 - 205 - 2M ohm - 1.958M ohm
R7 - 88D - 806K ohm -  0.77M ohm
R8 -  0 - 0 ohm - 0 ohm
R10 - 101 - 100 ohm - 100 ohms
R11 - 01E - 1M ohm - 0.988M ohm
R12 - 474 - 470K ohm - 0.470M ohm
R13 - 205 - 2M ohm - 1.98M ohm
R15 - 01E - 0.986M ohm
R16 - 01E - 0.987M ohm
R17 - 205 - 1.565M ohm
R18 - 01E -  0.985M ohm
R20 - 101 - 100 ohm - 100 ohm
R21 - 88D - 806K ohm - 0.805M ohm
R22 - 205 - 2M ohm - 1.829M ohm
R23 - 205 - 2M ohm - 1.563M ohm
R24 - 101 - 100 ohm - 100 ohm
R25 - 01E - 1M ohm - 1M ohm
R26 - 205 - 2M ohm - 1.951M ohm
R27 - 01E - 1M ohm - 0.984M ohm
Offline nali
« Reply #17 on: July 27, 2023, 08:44:04 am »
Sorry, I messed up yesterday, I meant to say bridge pins 1&3 not 1&2 with the resistor (was feeling under the weather which is why I was on here instead of working!). The o/p of U1 doesn't "pass through" anything as it looks to be an open-drain output so should basically do the same - bridging OUT & VSS when it asserts its output.
That should provide the PMOS (Q3?) with a Vgs to turn on via R8. (I think that the source of that FET i.e. junction of R7/R4 should be at VBAT +20V?). Then hopefully Q3/R13 node goes to VBAT.
« Reply #18 on: July 27, 2023, 10:14:38 am »
Ok I think I was looking at the cmos implementation, thanks for explaining.
So output is floating below 3v detect voltage or pulled down to VSS when above 3v detected, with a hysteresis width?
bridging pin 1 and 3 with 1kohm does pull the output to vss
you're correct with resistor added Q3 has Vss via R8, and VBat at R7/R4 and again at Q3/R13
though still no output at output pins.
Offline nali
« Reply #19 on: July 27, 2023, 10:43:50 am »
Looking at the datasheet for the Seiko/Ablic device it lookls like the o/p is pulled low when the battery is low, so looks like that end of the circuit is working. I'd expect the gate signal to pull up to VBAT so not sure about your 18.67V reading, probably your meter's internal Z affecting the reading.
You could temporarily remove R8 I suppose to isolate U1 & get on with fault finding.
Then back to the schematic I guess... it would make a bit more sense if you can redraw it in a more conventional manner once you've sussed out the physical connections.
« Reply #20 on: July 27, 2023, 11:09:56 am »
SOLVED
Replaced NCE40P13S and have cured the issue
R5 looked suspect measuring 674ohms vs expected 2M ohms
R5 is across the gate and source of NCE40P13S
Thank you to everyone who contributed to the thread and for your patience walking me through this one.
