Author Topic: Diagram needed  (Read 1664 times)
Offline sidspopTopic starter
Diagram needed
« on: March 03, 2018, 10:29:00 am »
Connections diagram for a Kenwood KAC-901 car amp. just the connections.
There appears to be precisely nothing on the internet to do with how it is connected.
Thanks
Offline PA0PBZ
Re: Diagram needed
« Reply #1 on: March 03, 2018, 10:45:57 am »
Here you can download the schematic, that should help: https://elektrotanya.com/kenwood_kac-901_amplifier_sch.pdf/download.html
Offline Bratster
Re: Diagram needed
« Reply #2 on: March 03, 2018, 10:51:21 am »
Edit: got ninja'd [emoji14]
Here's a link to a PDF of the schematic:
Didn't see anything for installation in a quick Google search but it may be out there.
Sent from my Nexus 6 using Tapatalk
Re: Diagram needed
« Reply #3 on: March 03, 2018, 12:23:31 pm »
already got that diagram, but it's a very poor scan of a photocopy. when blown up the definition (what there is) dissappears
Offline PA0PBZ
Re: Diagram needed
« Reply #4 on: March 03, 2018, 02:35:18 pm »
I'm not sure what you have been looking at, but the scan is of very good quality and it is easy to see where the connections are.
Offline coromonadalix
Re: Diagram needed
« Reply #5 on: March 03, 2018, 05:39:11 pm »
https://www.amp-performance.de/518-Kenwood-KAC-901.html    for photos
i had one of theses in the past,  normally you would connect the din  for left an right and the remote power up pins, you have din to rca plug converters too,  and in one photo you see the output plug with the power pins ...
Offline Bratster
Re: Diagram needed
« Reply #6 on: March 03, 2018, 06:34:12 pm »
Did you actually download the PDF file from linked webpage?
I had no problem zooming in on it and seeing everything just fine.
 The image on the page however is just low resolution
