Thanks for your input all.
Where I can envision someone touching the blocks input to the SMPS output....
I wish it were so simple, at least I've have my own stupidity to blame however the LN antenna was on the other side of the room debugging EMI from a GaN SEPIC converter which has proven very effective at generating airband RF! I digress...
Could it be that the N connector on the DC block was out of tolerance and bent the center contact fingers on the spectrum analyzer? Have you inspected them closely?
I'm but a budget operator and I thought my $60 DC should prove sufficient, there's every chance it was charged up in shipment and it's killed the unit. Moving forward, it's become a mission now-
I've begun validating the RF frontend, which has ruled out front panel connector issues and attenuator issues; keep in mind, this unit has a diplexer separating two functional bands, 0-3.2Ghz and >3.2Ghz in which the lower frequency is fed through an LP filter and the higher band through a YIG filter and on to the fundamental mixer. I only have a 1 GHz signal source, so I'm limited to the lower frequencies for now, but I'm hoping I can shed some light on something either way. Attaching my LN antenna to the input and tuning to the 5Ghz WiFi band I see no difference between the antenna being disconnected or connected, so I'm assuming the issue lies beyond the input section.
Everything in the signal path seems OK up until the lower band frequency conversion unit, where I'm able to confirm a stable 400MHz input from the TXCO; I'm not seeing any expected output onward to the IF change-over switch or fundamental mixer.
Measuring the 1st LO output on the back of the unit yields a very weak sinusoidal pattern with beats at around 100 MHz. However, the only measurement tool I have is a 300Mhz DSO (which I've checked with a 50ohm BNC pigtail and a probe with a BNC tip adaptor); I'm not sure if I should at least see some voltage or spurious emission on the scope here (esp at +10dBm).
I've attached some block diagrams of the measurement and conversion sections, would love any input on what a possible culprit could be (I know, it could be anything) but just hoping for a nudge in a direction in particular at present.
I'm fairly amateur in this realm and my experience and expertise is limited, especially when it comes to RF so please mind my ignorance which I promise accompanies a willingness to learn.
