Author Topic: Repair LED grow light  (Read 2677 times)
Offline GeronimosportTopic starter
« on: August 14, 2017, 08:48:10 pm »
I am a complete newb and am confused on LED power supply equivalents.  The part I need to replace is a RoHS (is that a cert or a brand?), Model NLNI-50XC-035A and it says Input 100-240VAC 50/60Hz Output 80-130v DC, 650mA.  Replacements I find are showing in watts and I am not sure what I need to buy.  I looked on the usual suspects but my Googlefu is weak on this one.  Can someone point me to a part? Tell me what I need? Thank you in advance.
Kenneth
Offline sokoloff
Re: Repair LED grow light
« Reply #1 on: August 15, 2017, 12:35:24 am »
You might be able to buy the exact replacement from here:
http://www.nldriver.com/product/product225.html
It appears to be a constant current driver. You say 650mA; the spec I found above says 300mA.
Once you decide which it is, you can just look for another constant current LED driver with the appropriate input and output voltage. I didn't find any with a quick search, but I only spent 3 minutes on it. You are presumably more motivated than I am.
In order of priority, you want the right current rating, then the right input voltage rating, then the right output voltage. You can compromise slightly on the last one, perhaps.
RoHS is a certification ("Reduction of Hazardous Substances", meaning lead free solder, among other things)
« Reply #2 on: August 15, 2017, 05:05:04 pm »
Thanks for the help, that is what I need just my Chinese is not very good, so that site is not usable for me.  Was thinking this would be simple! will keep looking.
Kenneth
Offline jmelson
« Reply #3 on: August 15, 2017, 07:18:07 pm »
Digi-Key stocks several THOUSAND LED lighting supplies.  Their search engine should be able to narrow it down by current and voltage rating.
Jon
Offline Toasty
  • Component Level Repair Tech
« Reply #4 on: August 17, 2017, 07:27:34 am »
Why not repair what you have?
veritas odium parit
