Author Topic: Help Identifying IC  (Read 1056 times)
Offline sfernandesTopic starter
Help Identifying IC
« on: February 28, 2020, 03:54:24 am »
The IC is from a Sony XAV-68BT Car Touchscreen Stereo It sits inside the unit right up against the back of the heatsink, I'm not sure if it's a power MOSFET or the amplifier, but it has two holes blown in it and the stereo will not power on just more smoke comes out of the part. I can't identify it because the burns removed some of the markings. Anyone have any ideas? I have attached a picture of the blown IC.
Offline helius
Re: Help Identifying IC
« Reply #1 on: February 28, 2020, 07:21:07 am »
It looks like a STA50013. How many pins does the package have?
The following users thanked this post: sfernandes
« Reply #2 on: February 28, 2020, 08:53:59 pm »
Here is better pictures.
« Reply #3 on: February 28, 2020, 08:56:50 pm »
more pictures
« Reply #4 on: February 28, 2020, 08:57:49 pm »
another picture of the bottom
« Reply #5 on: February 28, 2020, 09:00:23 pm »
looks to be 25 pins, but not an expert so not sure if I'm correct.
Offline amyk
« Reply #6 on: February 29, 2020, 12:34:35 am »
https://www.eevblog.com/forum/chat/pure6001h-datasheet/
Note, a TDA7850 should also work, they have the same pinout and according to the datasheet nearly everything is the same except for the quiescent current (one is very slightly higher.)
Edit: found even more pin-compatible amps, see pinout "Y" in this catalog: https://www.st.com/resource/en/selection_guide/sgaudiopow0315.pdf
« Last Edit: February 29, 2020, 01:00:22 am by amyk »
The following users thanked this post: helius
