Hi there,
I'm an EE student at University in the UK, so when my digital piano stopped functioning, I thought I'd take a look at it before letting somebody else do the work.
OK, digital piano works fine for five years, and then, blows the UK->EU socket fuse. I replace the fuse, the piano works fine for two minutes, then blows the fuse again. I replace the fuse, the piano doesn't turn on AT ALL.
I take the piano apart and my first area of diagnosis is the power supply board. I'm looking for dodgy capacitors here, five years is a long time and is about inline with the expected lifetime of some (cheaper) and even more expensive electrolytic caps.
[VOLTAGE SELECTOR ABOVE NOT PRESENT IN MY MODEL]
The board looks completely fine, there is no charring and the capacitors are very healthy looking. I take to the board with a cheap DMM to check for continuity etc, and everything is fine. The resistors have the correct values, and so on.
I add power to the board and go probing to check for voltages and then FZ3 blows - secondary side -- I'm unsure what I was probing at the time. It must be said that before FZ3 blew, the voltage from +18V to PGND was not 18 volts; it was significantly less. I continue probing and I get to checking the diodes. D1 and D2 are perfectly fine and R1 holds 1kOhms. The diode bridges were a funny one.
DB3 had continuity across its two middle pins - which from what I know, it shouldn't have by looking at the schematic.
DB1 worked fine.
So, I take the capacitor out (C5) and test it and it is open in both directions - so, it's fine(?). After taking C5 out, there is still continuity across the two middle pins of DB3.
I take DB3 out from the PCB and test it, its two middle pins are now open, no matter the direction - so, it's fine(?).
I will get back to this with some real voltage measurements when I can. Any ideas so far?
Kind regards
