Author Topic: Digital reverb SoC troubleshooting  (Read 1589 times)
Offline FranciscoPerezTopic starter
« on: February 29, 2024, 07:51:26 pm »
Hi guys.
I’m trying to troubleshoot an issue in a digital reverb circuit that’s driving me nuts. Here’s the schematic. Hope you could give some advice.its the reverb effect section of a musical instrument amplifier.
The unit worked great until one day it began making a harsh noise which was produced by u202 , a bd3201 reverb SoC. I didn’t have a scope at the time and decided to replace it. Hearing at the symptoms someone said probably the DRAM inside the bd3201 had failed and was making errors. After replacing the noise went away, but u202 is not outputting any signal and I’m not getting any reverb sound at all. Dry signal works as expected and the amplifier is usable, but without any reverb effect to it.
Now I have a scope available so I could troubleshoot this further, but I’m quite a newbie in digital circuits and don’t know where to start. I’d like to check mostly if the adc u201 before the reverb chip is outputting the digital converted input signal and whether the bd3201 is receiving a good digital input signal . My scope also has a function generator , so I can inject say a 500hz signal to the amplifier, for testing.
What should I expect to see when probing the adc output pin and the bd3201 input? Any other troubleshooting advice I could perform to trace down the problem is strongly appreciated!
Thank you all.
Cheers
Fran
Re: Digital reverb SoC troubleshooting
« Reply #1 on: March 06, 2024, 03:26:01 pm »
I grabbed a scope, and probed all pins of bd3201 hoping someone more experienced could shed some light on this.
Injected a 0,2v 500Hz sin signal through the amp's input, and this is what I got:
BD3201 Pin 01 Digital OUT: IMG_9277.jpg
BD3201 Pin 03 and Pin 04 XTAL IN and OUT: IMG_9280 and IMG_9281
BD3201 Pin 16 DIGITAL INPUT : IMG_9278
BD3201 Pin 14 VDD: IMG_9282
BD3201 Pin 13 GND: IMG_9283
BD3201 Pin 12 !Reset: IMG_9284
BD3201 Pin 11 Sysclock: IMG_9285
BD3201 Pin 10 Bitclock: IMG_9286
BD3201 Pin 09 Wordclock: IMG_9287
All signals but the Digital OUT look right to me. Can you spot something which does not look good??
« Last Edit: March 06, 2024, 03:27:44 pm by FranciscoPerez »
