I have this old salvaged Acer LCD CCFL monitor w/ VGA connector, which I need sometimes. And it looks pretty dull and washed out.
So I took it apart, without probing or measuring anything when running, and mapped the whole PSU. I just wondering what to look for.
It runs of mains power, then has a flyback converter for 5V, Vaux, and a 40V or so rail. That rail feeds a half-bridge inverter for the high voltage.
There's only 5 electrolytic caps in total, and they have great ESR and DF.
I'm new to the half-bridge layout, in the primary side of it, I see the upper and lower cap's, that sit on 1 end of the primary inductor. They use 2 pair's of SMD, ceramic 2.4uF each. At least that's what they measure out of circuit at LV. I never tried their ESR, IDK what it should be anyways, or what rating these might have since they are SMD.
What's they chances they degraded, or the 2 mosfets. Also in the datasheets, the Nch had a way higher K value, like 10x, then the P-ch fet, I wonder why they are so different, like 6S vs 64S ?
The inverter controller IC is a INL816 , I can't find a DS, but at least I found a pinout that matches
https://www.datasheetq.com/INL816-doc-ETCI see 3kV rated caps on the HV side, that pass the Vsen info to the IC. And I see the lamps are just sinked into a 4.7k+470 divder, and that is the current sensing.
So besides maybe SMD caps or the HV caps, what else could be going wrong ? I want to probe the flyback HV, and the Vsen and Isen of the inverter chip. But I don't have a data sheet for the inverter IC, so IDK.
Below is the basic layout of the PSU, then there's just a little VGA output board.
