Ok,
Friends hard drive failed but now makes no noise at all so I said pop it over
The Drive is a Samsung Model HM320ii in a Lacie powered external enclosure.
Taking advantage of my new Bench power supply, I set the current to the minimum load of 2A which is 200mA under the dedicated power supply for this device.
This is where I learned how important it is to have some of theses current limiting bench power supplies is.
1. I worked out where positive and negative were oriented on the chassis by doing a quick examination and then confirming with a continuity check
2. After setting the correct voltage and current, I connected my power supply to the correct rails on the chassis power board.
3. Immediately after enabling the powered circuit I observed that the voltage dropped to 1.2V and the current had ceilinged to my pre-set of 2A.
Something was shorted or blown
4. I detached the drive from the chassis and powered the chassis drive free, same result.
I deducted that the short was on the logic board as I got the same result with or without the drive attached.
5. Detached the Logic board from the drive and found this
Damn, Damn
What would cause this and what part has blown, has the memory been damaged?
What would you guys suggest?
I'm thinking is buy an identical drive and retrieve the data as quick as possible , BUT
Has the drive been damaged or if not, is the drive going to blow a new logic board
Any ideas are welcome
