This is from SmartDrive MX1+ wheelchair motor. Pins welded themselves inside the connector, want to check if its possible to replace the connector at all.
Anyone recognize the connector or logo? Looking through digikey at the moment.
Plug description:
- 6 pin DIN style connector, with latching portion above
- 13.5mm OD on the plug side
- "G" symbol on the connector
Receptacle:
- pin diameter ~1.5mm
- o-ring seal
Seems reasonably well designed with sealing, silicone. Board is not coated though.
edit: the dimension seems to match a M16 connector.
