Has no markings at all, this switcher converts 300V dc to 5V 6A, claimed. Comparable to Power Integrations devices.
The traced pinout is:
1: GND, 300V Minus
2: Unknown, has 220R to Vcc cap Plus
3: Vcc, 10uF cap fed by a transformer sec, with 2×500k to 300V for startup
4: FB, from Opto LED
5: Source of switch, has 560mR 0.5W to power ground
6, 7 and 8: Drain, to transformer primary.
All 8 pins present, none deleted to extend hv drain clearance.
Problem is: it is kaput, SHORT between 2 and 3. Vcc builds up to 17.5V nevertheless. No switching action though. Power mosfet tests OK, source to drain..
Claim of 30W output with not much heatsinking estate on PCB is suspect.
My Google and other searches have failed. Anybody can identify this IC?
Thanks in advance.
