I need BIG help. This is a vacuum dirt sensor circuit made of 2 boards. I've reverse engineered the circuits as best I can. The circuits are floating AC powered, I cannot attach a scope to see the traces as it causes the LEDs to turn on very bright and I even smoked a 220 Ohm resistor when I attached the ground lead to the scope.
As dirt interrupts the IR between D1 and D2, LEDs labeled Gled (Green Led) and Rled (Red Led) switch logic states, then switch back after 3 -4 seconds. The circuit does work, except the transition from a lit Rled to a lit Gled is slow taking 2-3 seconds to turn the Gled on to full brightness.. A good circuit changed states in 1/2 sec.
I don't understand Op amps well and cannot figure out where the cap is that controls the transition of the Leds. Í also don't understand what the D6-D9 bridge does.
There are x2 3 pin SOT23 devices controlled by the OpAmp, I suspect one is an NPN, the other is ?? maybe a MOSFET ?? The pinout on Q2 does not match NPN, PNP transistors. I can't ID the caps as they are ceramic SMD devices.
Any thoughts on this circuit (attached) would be appreciated as I'm going bald from scratching my head. Thank you
