Author Topic: Help identify switch output enable switch for Farnell AP6050 PSU  (Read 637 times)
Offline aqibi2000Topic starter
Have a Farnell AP60-50 Power supply, the output enamel switch was sticky, as I removed the cover I found an internal spring broken (BER).
Can someone please help identify what type of switch this actually is, believe it was a latching type
There are 8 pins for the mounting and internally I can see 8 individual contacts… 4PDT???
The brand of the switch is MEC.
Thanks!
« Last Edit: October 09, 2021, 06:02:34 pm by aqibi2000 »
Tinkerer’
Re: Help identify switch output enable switch for Farnell AP6050 PSU
« Reply #1 on: October 09, 2021, 06:06:49 pm »
I’m under the assumption it is called a 15.551 switch based upon colour
Tinkerer’
« Reply #2 on: October 09, 2021, 06:23:03 pm »
Managed to fix the switch so it works when I hold it in (latching function does not work because the flexible metal pin is broken which is also why it was sticky)
Tinkerer’
« Reply #3 on: October 09, 2021, 08:11:19 pm »
Ordered a 15451 which is a high temperature version of the 15551.
Any ideas if this is the right one, it’s Circuit: 4PST-2NO/2NC
https://www.ebay.co.uk/itm/SWITCH-PUSH-4PST-0-25A-120V-/124340016475?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
Tinkerer’
« Reply #4 on: October 16, 2021, 10:25:11 am »
No one?
Tinkerer’
