Author Topic: Dispensing needles  (Read 2277 times)
Offline akisTopic starter
Dispensing needles
« on: April 28, 2016, 07:27:31 am »
I am looking for a needle to put at the end of a syringe, or at the end of a squeeze-able bottle, length about 8cm=12cm (3"-4") small diameter (hence needle, not straw), but it must be plastic, blunt, and flexible. I was thinking max 2mm outside diameter. Can't find anything like that on Amazon but my search skills aren't that great.
Re: Dispensing needles
« Reply #1 on: May 01, 2016, 09:24:36 am »
OK I know what I want, but I cannot find it easily.
Know the WD40 cans that have a very thin piece of dispensing tube stuck to the side? This is the exact tube I need. It has the right length, diameter and rigidness. Short of re-purposing it from old WD40 cans I have no idea where to get it from. Any ideas?
« Reply #2 on: May 01, 2016, 09:46:20 am »
Just wondering if a very small diameter PVC air line tubing is what you need?  :-\
« Reply #3 on: May 01, 2016, 10:20:30 am »
The smallest I can see is like 5mm external diameter. I need something like a needle really, like 2mm external max.
« Reply #4 on: May 01, 2016, 10:34:34 am »
Aerosol tubes that I've just measured are 2.1 -2.7mm so something like this might do the trick for you:  :-\
http://nz.rs-online.com/web/p/flexible-tubes/3139454/
Offline rolycat
« Reply #5 on: May 01, 2016, 11:00:59 am »
Tygon is very flexible, so I suspect this doesn't match the OP's requirement for rigidity.
These might fit the bill:
Sold by fishing tackle suppliers.
A pack of 10 tubes is around £1.49, for example here.
« Reply #6 on: May 01, 2016, 09:46:40 pm »
I ordered one thanks.
Offline john_p_wi
