Author Topic: Golden poker double up arcade machine schematic  (Read 1550 times)
Offline james_s
Re: Golden poker double up arcade machine schematic
« Reply #25 on: March 22, 2020, 10:36:18 pm »
Nicotine is oily, plain water usually isn't too effective but a bit of detergent will let it dissolve and rinse off. I like Oil Eater but regular liquid dish soap works reasonably well too.
The following users thanked this post: uraniumman
Offline poot36
« Reply #26 on: March 23, 2020, 12:02:44 am »
I think most of it was surface dust that got coated with the cigarette smoke.  I can now read the values on the trimmer pots and caps.  It is currently drying over a hot air vent.  I will then start testing all the caps on the board.
Offline uraniumman
« Reply #27 on: April 02, 2020, 08:22:11 pm »
thank you
