I've received this little fella but V range shows OL all the time. Diode and temperature are not working properly.
I've checked all the input components, sparks gaps are open, PTC are around 1.5k and resistors are fine.
I was not able to find a proper schematic. I've learned that this is a common design in other rebranded meter.
I've lifted pin 35 VR1 "measurement input" and it's at around 1.2V all the time. So I reckon the IC is fried and needs to be replaced, but I cannot find any for sale. It's a Cyrustek ES51962
http://www.cyrustek.com.tw/spec/ES51962.pdf
has anyone found a source for this old IC?
Another option will be to salvage the part from like a unit T70B, but I was not able to find a broken one for spares!
