I've received as a 'gift' a lot of broken
multimeter
and I'm trying to get them back from the dead ..
The first one is a Fluke 87:
Symptoms:
mV --> OL
V --> around 0.030 V with crossed leads. I can measure correctly a 9v battery
--> jumping around 64K. Crossed leads -> still 64k
diode --> OL
test made:
dial test (rotary switch test - holding range button while powering )-> OK
input fusible resistor -> around 1k
spark gap -> open
2 mov -> Open
thermistor -> 8.5 K (should be 1,5k but schematic is not 100% matching. swapped with a 1.5 resistor, same behavior)
voltage reference zenner -> around 1.2 V
mA and A works fine.
all power supply lines indicated in service manual are within specs.
I cannot spot any damaged components on the board itself.
I've looked at the schematics, very well made but I'm not able to spot a component that could trigger this kind of behavior.
Is there a way to bypass or force a reading directly to the main uC pins?
If anyone as some kind of advice, it would be a great opportunity to learn something new and to put a great instrument into my drawer!
