Sounds like a bad contact or open (fusible?) resistor in series with the input to me. What is the input that you measure when you measure resistance with the meter set to DCV between the V/Ohm terminaland COM terminal with another DMM, and what is the input impedance specified in the manual for that DCV range? And is this value stable or does it slowly change like the reading on the defective DMM?
