Author Topic: DMM resistance test, shows abnormally high values  (Read 559 times)
Offline sdancer75Topic starter
  • Country: gr
« on: July 02, 2020, 05:30:42 pm »
This is my spare "mobile" DMM that I am using out of home for emergency situations. I always store it in my car.
Lately, I noticed that sometimes -but not every time- it shows high resistance but after a while (~5 to 10 minutes), it comes back to normal.
As far as I know after a quick test, AC, DC, Diode, and capacity work fine. Probes also are fine.
What kind of problem is this? Maybe a rusty connection or high temps inside my car?
« Last Edit: July 02, 2020, 05:33:29 pm by sdancer75 »
Offline bob91343
Re: DMM resistance test, shows abnormally high values
« Reply #1 on: July 02, 2020, 05:48:04 pm »
This is simply a poor connection.  It can be in the switch or the test jacks.  Even a slight corrosion of the test probes can cause it.
That's why a four wire Ohms setup is far superior; it doesn't much care about such things.
The following users thanked this post: sdancer75
  • Country: gr
« Reply #2 on: July 02, 2020, 06:04:59 pm »
That's what I thought. I will open it to check it out.
Thanx
