Author Topic: do freezing NiCad rejuvenate them or what would you recommend  (Read 2542 times)
Offline pcmadTopic starter
    • module web design
Offline wraper
  • Country: lv
Re: do freezing NiCad rejuvenate them or what would you recommend
« Reply #1 on: April 14, 2021, 08:48:30 pm »
Why some random action should restore them?
Disposing them.
The following users thanked this post: AmnevaR
Offline joseph nicholas
  • Country: mx
« Reply #2 on: April 14, 2021, 09:33:44 pm »
Everything wears out, get use to it.
Offline RoGeorge
« Reply #3 on: April 14, 2021, 10:19:27 pm »
Ni-Cd rechargeable batteries have memory.  Try a few cycles of discharging them to zero volts then charging, in order to remove the unwanted memorized discharge level.
Another common mode to fail is they grow dendrites internally and short circuit themselves.  This fail mode can be removed by braking the dendrites with a very high current pass through the battery.  It works but soon the dendrites will grow again, so this kind of recovery is not very useful.
NiCd technology was replaced long time ago by NiMH or Li based rechargeable batteries, so long ago that most of the times it doesn't worth trying to recover NiCd.
The following users thanked this post: pcmad
Offline Monkeh
« Reply #4 on: April 15, 2021, 12:41:19 am »
Not on planet earth they don't.
The following users thanked this post: BrokenYugo
Offline Monkeh
« Reply #6 on: April 15, 2021, 01:06:12 am »
https://www.electronics-notes.com/articles/electronic_components/battery-technology/nicad-nicd-nickel-cadmium-memory-effect.php
Which references my point.
You need consistent charge/discharge cycles to see the memory effect, far more consistent than you'll see in consumer use. It was discovered on satellites.
Offline MikeK
« Reply #7 on: April 15, 2021, 01:31:33 am »
The "memory" effect originated with satellite use, having very specific and regular charging circumstances.  See the wikipedia page on it.  Most people won't experience it.
Anywho...
Why are these NiCads being rejuvenated?  Are they old and at the end of their life?  Or something else?
Offline james_s
« Reply #9 on: April 15, 2021, 05:45:29 am »
I've managed to squeezer a little more usable life out of tired NiCd batteries but generally speaking it isn't really worth it. At some point they're just worn out and the only thing you can do is replace them.
