Hello Team-EEVBlog,
I am just curious if it is normal for oscilloscope probes just die and give up working instantenously?
I have had a Keysight MSOX2022A for a number of years and have been using the stock N2890A 500MHZ Passive 10:1 probes for a while.
Today one just stopped working. It is definitely not the scope channels as swapping probes over moves the fault, so it's definitely the probe. I've tried copious amount of cable wiggling and checking the tip, taking the shroud off, and no joy. It just behaves on screen as if it's not plugged in; absolutely zero signal of any variety shown.
I wasn't probing anything dangerous when it failed... just a pretty simple 5V TTL serial signal.
I don't want to repair it, I'm just curious on the failure mechanism and if it's common should anyone knows? Coax fatigue?
There can't be much inside these passive probes to go wrong surely.
All the best,
Dan
