Author Topic: Do these caps fail often in Tek gear?  (Read 6308 times)
Offline EPTech
    • EP Technical Services
Re: Do these caps fail often in Tek gear?
« Reply #25 on: August 16, 2016, 08:00:18 pm »
Yep,
Repaired a TEK 465 where one of those shorted out the power rail.
More recently one SMD tantalum also shorted out a power rail in the VAC III spindel drive of my Okuma LCS15 CNC lathe. A 2 by 3 mm SMD crippling a 3500kg machine.  |O Stil it is 20years old already, so one might expect that to happen eventually. Well as long as it's repairable I'm happy.
Kind greetings,
Pascal.
