Didnt have time to reorder the new IC yet, so I cant report any news on the repair front. Plus, I opened up the 34401A I thought to have just ohms current source problems - nada, the entire DC Voltage area seems fooked, while the current source I spent hours repairing was fine and dandy all along.
But, in the mean time. AFAIK, there are two versions of the TEK754D planar in da haus: I cannot say anything about earlier versions (" ", A, B and C).
The one, which has BGA memory controllers and FOUR memory ICs is the 2M model and IMHO can not be upgraded. The one I have, picture attached, afaik is the 8M capable model. Why? Well. The same layout is also at the bottom of the acquisition board, which I had out recently but was too lazy to make a photo of its back. So we have 16 of these memory ICs per channel, which gives a whopping 8M sample space if I am not totally confused (which can be). If I recall correctly, upgrading involves the sending of some PITBULL GPIB command...
