Author Topic: Do you know how to clean these rotary switch - Instek GOS-620 [Solved]  (Read 2042 times)
Offline ArmadilloTopic starter
Do you know how to clean the contacts of these rotary switches from the Instek GOS-620?
I am also thinking of de-soldering it out to pry the plastic seal, but the front pull knob [smaller one] cannot be pulled out.
 |O  :palm:  :-//
thanks
« Last Edit: October 11, 2017, 09:48:24 am by Armadillo »
Offline cdev
Re: Do you know how to clean these rotary switch - Instek GOS-620
« Reply #1 on: October 11, 2017, 04:16:40 am »
First i would email GW instek and ask them what they recommend..
For rotary switches generally, I use a tiny bit of Craig (I may be wrong on the spelling) "Deoxit"-Just a tiny bit on the contacts and then work the switch and clean any excess off. It makes a dramatic improvement. Don't use too much. just the tiniest amount.
« Last Edit: October 11, 2017, 04:27:25 am by cdev »
Re: Do you know how to clean these rotary switch - Instek GOS-620 [Solved]
« Reply #2 on: October 11, 2017, 09:47:44 am »
@cdev;
thanks, done, manage to dismantle the board out and clean it.
