Greetings everyone,
I hope you can help me solving a problem that I can't solve by myself.
I'm not a professional repairman but I like to fix broken appliances given to me by my friends and colleagues (Hey! I know you know electronics...can you fix THIS?
The things I've fixed successfully so far are battery chargers (RC-Car-Racing stuff), SMPSs (mostly in TVs and PCs), some Electronic instruments (Synthesizers and Samplers from the 80s and early 90s, mostly powersupply issues )
Now I was asked to look after a broken Studio Strobe. I cant't identify the problem but have tried some things...all without luck.
It would be very nice if someone could put me in the right direction to bring the unit back to a working order.
I know mains voltage stuff with large capacitors is quite dangerous, but if I had done something seriously wrong I would not be able to post my problems here.
Here is a description of what I've done so far.
Attached are some photos of the PCBs. The wiring inside is quite messy.
If I need to provide additional information, please tell me what is needed.
The unit is a Doerr DE300B, 300 Ws. I think it's from around 2009.
It seems it is also marketed as Falcon Eyes DE-300B - When I got the unit the guy who was using it told me it trips the Studio RCD when the unit is triggered (regardless if triggered over sync or with the test button)
- It tripped the RCD when hitting the test button
- No flash, no “tick” on triggering
- On some occasions the RCD was tripped when the unit was switched on
- The trigger transformer was defective
- With the trigger transformer removed the RCD was not tripped when the unit was switched on
- After replacing the trigger transformer the unit still trips the RCD, sometimes when switched on sometimes on the first trigger sometimes on the second or third trigger
- A “tick” is heard when the unit is triggered
- When the flash tube is removed the unit can be switched on without tripping the RCD
- If the PE is disconected in the unit, the RCD does not trip, a “tick” is heard but there is no flash
- The RCD is still tripped if the TRIAC in the trigger circuit is removed
- The tube was tested in another unit and produces a flash (In this unit the lowest setting sets the voltage to ~150V)
- The voltage on the capacitors is ~170V on the lowest setting and ~320V on the highest setting
- The Triac in the trigger circuit was replaced
- How can I determine if the trigger transformer is of the right type? All transformers and datasheets I found look the same (resistance/pinout/pulse waveform)
- The measured resistance values of the trigger transformers appear to be the same (of the replacement one and the one in the test unit, which is of a different make)
Thanks in advance for your time and help!
Regards,
Jens
