Author Topic: Does anyone know how to add chips to xgecut56  (Read 1781 times)
Offline psxpetey1Topic starter
« on: October 31, 2022, 06:36:46 pm »
I know you can pick a chip of similiar size and modify that, but what if I wanted to add everything manually as that doesnt really "ADD" a chip. for example I want to add the XILINX XC1765ELSO8C PROM Serial 64K-Bit 3.3V 8-Pin SOIC. I did find a chip in the device list that was the same size well upon looking at the datasheet its not really similiar at all apparently its 512 divided into 64kbit parts must have been added wrong. Anyway Going through a massive list of chips just guessing at one that may be similar is stupid and nobody has time for that. So How can I manually add All the configurations in the datasheet of the XILINX XC1765ELSO8C PROM Serial 64K-Bit 3.3V 8-Pin SOIC. This programmer is the successor to the tl866
Online coromonadalix
Re: Does anyone know how to add chips to xgecut56
« Reply #1 on: November 01, 2022, 02:23:35 pm »
the t48 is supposed to be the tl866 successor, not the t56
Normally for theses,  you try to send them some emails and ask them to integrate the chip in their parts "definitions" ...
« Reply #2 on: November 15, 2022, 09:30:56 pm »
thats so annoying it doesnt even look hard to do but they block out so many feilds or grey them out lol
« Reply #3 on: November 17, 2022, 05:40:33 pm »
if it was "not hard"  we should had news  of this ???
Offline Symeon
Re: Does anyone know how to add PIC18F14K22 drives for TL866II
« Reply #4 on: June 19, 2024, 10:30:41 am »
Hello everybody,
even today and being 8bit micros,this family was not included in any official list....any ideas???
thank you  |O
Offline kevin.gibbs
    • Teardown it!
« Reply #5 on: January 17, 2025, 02:50:47 am »
This programmer does not have an independent addition of chips for programming. It is only possible to add logic chips (registers, decoders, triggers, and so on) to test them for operability. But almost all logic is already added by manufacturers or enthusiasts.
Teardown, research, create!
« Reply #6 on: January 17, 2025, 10:13:25 am »
i think its embedded in the executable, and maybe decompress in the computer memory
just to let you know,    a new model is out  XGecu T76     it does both 56 and 48 ...
normally  you send requests to the makers  and maybe they'll add a new chip ?
no afilliations
T76 Hardware Parameters
●Master:32-bit RISC-V MCU + FPGA (BGA256)
[TYEP C] USB3.0 SS 5GHZ Compatible USB2.0 480MHZ
●Exterior Dimension: 12x7x2.8cm
High-cost and high-density process, product size is greatly reduced.
● 48-pin full drive 10+ISP 28-way dedicated I0.
A total of 76-way external high-speed driver, high reliability
●VCC voltage 1.2-6.5V 64-level adjustable, the
VPP voltage 6.5-25V 64-level adjustable. Supports programming up to 25V
I0 communication signal voltage 1.2V-3.6V adjustable in 64 steps.
VCC 120MA-450MA overcurrent protection adjustable
VPP 150MA overcurrent protection
Power consumption: 5V <1A. Static power consumption: 150mA.
All chips do not need external power supply. For one to four mass production programming can be connected to an external power supply 5V-5.5V.
External power supply current n*1A or more, the programmer has multiple protection for external power supply.
Over-voltage protection / reverse connection protection / over-current protection / low voltage tips.
T76 chip support
●26 27 28 29 37 39 49 50 Series Parallel ROM, EPROM, EEPROM
●24 25 35 45 85 93 95 Serial series EEPROM.
●Support P-NAND FLASH: NAND New model chips can be added with customized parameters.
●Support SPI NAND, (SD NAND/SD Card)
●Support EMMC/EMCP
● Microcontroller series
●GAL/CPLD Programmable Logic Device Programming
● Support VGA tool and VGA ISP programming
●SRAM chip test
●Powerful 54/74F/LS/HC CMOS4000 series IC logic test.
