Picked up my 33XR-A back in 2018 for $36.35 from Amazon Warehouse. I also bought it because it was a good deal.
Beeper leads were cut most likely because it's very loud?
Fuse might be blown because this DMM uses the mA/uA jack for capacitance measurements, although it's easy to blow a mA fuse when measuring current too.
Continuity function is shared with diode, so it's glacial in my opinion. (Capacitance is slow too, IMHO.)
Also, while it can count higher frequencies, the voltage/current measurement specifications are only rated from 45Hz to 500Hz.
Annoyingly, there are at least a handful of different permutations of this thing floating around. 1MHz, 4MHz and 40MHz frequency ability, Wavetek/Meterman/Amprobe branding, and 33XR or 33XR-A, and various labels for the frequency dial position. Mine is Amprobe 33XR-A branded, 4MHz but the dial simply says "Hz".
