Author Topic: Does IT8528E I/O chip require programming before use?  (Read 5854 times)
Offline toriniTopic starter
  • Country: hu
« on: January 14, 2019, 03:19:14 pm »
Need to replace one of these chips, does it need to be programmed?
Offline khaahk
Re: Does IT8528E I/O chip require programming before use?
« Reply #1 on: January 14, 2019, 06:03:41 pm »
No
Offline amyk
« Reply #2 on: January 15, 2019, 03:44:52 am »
No
Do you have a datasheet?
Some of the ITE ECs share the same flash as the BIOS, others have their own internal flash.
Offline fzabkar
« Reply #3 on: January 15, 2019, 04:40:50 am »
It's not a datasheet, but it might help you to work out whether it has any flash.
http://datasheetcafe.databank.netdna-cdn.com/wp-content/uploads/2015/09/IT8528E.pdf
From the block diagram, it would appear that the "SPI ROM 4MB (BIOS/EC)" is external.
« Last Edit: January 15, 2019, 04:43:35 am by fzabkar »
The following users thanked this post: amyk, coromonadalix
