I should have checked the 120 ohm resistor, although a failure of that part would have been my last choice. The 1000 uF capacitor had been replaced
by the previous owner at some time, and since the SCR was firing with my externally supplied pure 42.8 volts, it probably isn't the culprit either.
I think, in retrospect, that it was an over-current fault, as supplied by the 0.51 ohm sense resistor on the inverter transformer, rather than an over-
voltage fault. With my external 42.8 supply, every time I cranked it up, it would fire the SCR at just a little bit higher voltage, e.g., 35, 36, 37 volts...
I have seen many repair instances where the electrolytics needed a little time to reform after decades of non-use. I think that may have been the case
here. The electrolytics on the the various secondaries of the supply just needed a little time to come up to speed. Once everything settled in and the
current dropped to normal, the SCR and Zener operated properly since there was nothing wrong with both of them to begin with.
At least that's my guess (until such time as the scope breaks!).
