Author Topic: Does this look like a fuse  (Read 295 times)
Offline Ground_LoopTopic starter
« on: December 15, 2024, 07:57:10 pm »
While troubleshooting a power supply I found two of these that indicate open. I’m guessing they are fuses.  The same ones on a different operating channel are dead shorts. Anyone happen to have a schematic for a R&S 3040 power supply channel?
2462315-0
« Last Edit: December 15, 2024, 08:49:59 pm by Ground_Loop »
There's no point getting old if you don't have stories.
Offline Harry_22
Re: Does this look like a fuse
« Reply #1 on: December 15, 2024, 08:01:38 pm »
Hi!
Is it R&S power supply? It also has Fast 7A in parallel.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: December 15, 2024, 08:02:57 pm »
Yes, that's a fuse
Day Job: Mostly LEDs
Online fzabkar
« Reply #3 on: December 15, 2024, 08:05:30 pm »
The logo belongs to Littelfuse.
https://www.google.com/search?q=Littelfuse+7a+smt&num=10&newwindow=1&udm=2
« Last Edit: December 15, 2024, 08:08:44 pm by fzabkar »
« Reply #4 on: December 15, 2024, 08:09:39 pm »
Hi!
Yes. Channel 4 crapped out.  Both fuses are gone. You sure it’s parallel?
