i got my hands on a Rohde & Schwarz ZVRE Network analyzer. Of course it is not working
It boots Windows NT fine, but either hangs at the Splash info screen, or directly after the VNA application is started. It doesn't react to keypresses or anything else, but Windows NT keeps running, so the Main CPU is ok.
Sometimes it says ZVR instead of 'ZVRE' at the splash screen. The log files show:
Boot Log File created
Date: 09/24/22
Time: 08:03:48
Mailbox created 'TRIGGER_MBX' [8] ID : 385
Mailbox created 'SPOOLER_MBX' [20] ID : 386
Mailbox created 'PARSER_MBX' [8] ID : 387
Mailbox created 'OPC_MBX' [8] ID : 388
Mailbox created 'MOUSE_MBX' [8] ID : 389
Mailbox created 'MAINAPP_MBX' [8] ID : 390
Mailbox created 'LPTIO_MBX' [8] ID : 391
Mailbox created 'LINK_MBX' [8] ID : 392
Mailbox created 'IECSTATE_MBX' [8] ID : 393
Mailbox created 'GUI_MBX' [20] ID : 394
Mailbox created 'GUI_LNK_QMBX' [8] ID : 395
Mailbox created 'FPNL_RGI_QBX' [8] ID : 396
Mailbox created 'FPNL_PGI_QBX' [8] ID : 397
Mailbox created 'FPNL_PER_QBX' [8] ID : 398
Mailbox created 'FPNL_MRC_MBX' [8] ID : 399
Mailbox created 'FPNL_MPL_MBX' [8] ID : 400
Mailbox created 'FPNL_MBX' [8] ID : 401
Mailbox created 'FPNL_GUI_QBX' [8] ID : 402
Mailbox created 'FILE_TRC_MBX' [8] ID : 403
Mailbox created 'FILE_MBX' [8] ID : 404
Mailbox created 'EXTDEV_MBX' [8] ID : 405
Mailbox created 'ERROR_MBX' [50] ID : 406
Mailbox created 'COM2_MBX' [8] ID : 407
Mailbox created 'COM1_MBX' [8] ID : 408
Mailbox created 'BEEPER_MBX' [8] ID : 409
Mailbox created 'API_TP_QMBX' [8] ID : 410
Mailbox created 'API_MBX' [20] ID : 411
Mailbox created 'API_LNK_QMBX' [8] ID : 412
Mailbox created 'API_GUI_AMBX' [8] ID : 413
Mailbox created 'API_GEN_QMBX' [8] ID : 414
Mailbox created 'API_COM2_QMB' [8] ID : 415
Mailbox created 'API_COM1_QMB' [8] ID : 416
Mailbox created 'ALARM_MBX' [8] ID : 417
Started thread 'InitialisationMain', Priority NORMAL
Loaded DLL 'LINK_JOB'
Loaded DLL 'ERR_JOB'
Loaded DLL 'API_JOB'
Loaded DLL 'GUI_JOB'
Loaded DLL 'TIMER_JOB'
Started thread 'TimerControlLoop', Priority NORMAL
Loaded DLL 'PARSER_JOB'
Spooler DLL Initialising
SpoolController Object Created
Loaded DLL 'SPOOLER_JOB'
Started thread 'Spool', Priority NORMAL
Loaded DLL 'EXTDEV_JOB'
Calling init function: FPNL.DLL init function
Calling init function: LINK.DLL init function
Started thread 'FPNL key', Priority NORMAL
Started thread 'FPNL config', Priority NORMAL
Started thread 'FPNL macro player', Priority NORMAL
Started thread 'FPNL macro recorder', Priority NORMAL
Started thread, Priority NORMAL
Link job: Error downloading C:\R_S\INSTR\TP\R4_RUN_Z.BTL
Calling init function: ERR.DLL init function
Calling init function: API.DLL init function
Started thread 'Link send', Priority NORMAL
Started thread 'Link receive', Priority NORMAL
Started thread 'Link file I/O', Priority NORMAL
Started thread 'ERROR_TASK', Priority NORMAL
Calling init function: GUI.DLL init function
Started thread 'API_CDT', Priority NORMAL
Started thread 'API_TRGCT', Priority NORMAL
Started thread 'API_HWDUMP', Priority NORMAL
Calling init function: PARSER.DLL init function
Started thread 'GUI_CDT', Priority NORMAL
Started thread 'IECSTATE thread', Priority NORMAL
Started thread 'Parser monitor', Priority NORMAL
Started thread 'Parser', Priority NORMAL
Calling init function: EXTDEV.DLL init function
Started thread 'Parser pipe server', Priority NORMAL
Started thread 'PARSER OCAS/OPC', Priority NORMAL
Started thread 'RSIB State Channel thread', Priority NORMAL
Started thread 'RSIB wait for connection thread', Priority NORMAL
Enable message sent to 'GUI_MBX'
JOB_ENABLE received
Enable message sent to 'API_MBX'
Watchdog Task: Watchdog disabled
Started thread 'MainApp', Priority NORMAL
Started thread 'API_CMOS_ST', Priority NORMAL
Deleting SpoolController Object
The 'Error downloading...' Message above is likely the problem (although sometimes it says succeeded but the analyzer also doesn't work). Anyone here with experience working on these Analyzer? I'm not sure where to start digging...
