Author Topic: [Fixed] Don't laugh at me, but in 2019 I need to fix a VHS Player  (Read 2630 times)
Offline ZuccaTopic starter
  • EE meid in Itali
Short Story: my father broke his beloved VHS Player JVC HR-S8600: it always spits the cassette out.
I found these two mechanical parts that were rattling free inside the device:
I have no clue where they were mounted!
It looks like they were joint together, like this:
Maybe some of you were working on those units and remember what to do or were the hell those parts falls of from this device:
This above is the top part, I have the feeling those were mounted on the bottom part. Yes I hate mechanical problems in electronics devices. :P
Service Manual:
https://www.dropbox.com/s/gjqm1sdyjksuntr/jvc_hr_s8600_s9600.pdf?dl=0
Other Pictures:
https://www.dropbox.com/sh/7moqrfjf6e19e83/AABqthYODrzixbzo_PyyDzAma?dl=0
Thanks in advance!
« Last Edit: April 09, 2019, 09:58:35 pm by zucca »
Offline Mickster
  • Country: bm
Re: Don't laugh at me, but in 2019 I need to fix a VHS Player
« Reply #1 on: April 08, 2019, 10:32:57 pm »
Wild Arsed Guess...
Can you see a photo-interrupter somewhere around the cassette loading mechanism, which doesn't have anything to erm interrupt it?
Online Psi
« Reply #2 on: April 08, 2019, 10:45:34 pm »
I had a quick look and couldn't see anything obvious.
I would focus your investigation in this area.
It's likely broken due to the force of inserting a tape and this is where those sort of parts are.
I don't think you have much choice but to first remove the entire tape loading module from the VCR so that you can see it properly on all sides.
Take a video of everything you do to when removing it. Then you will have a reference to check when reassembling if you're not sure where something goes or what connector goes where.
« Last Edit: April 08, 2019, 10:49:22 pm by Psi »
Offline zed65
« Reply #3 on: April 08, 2019, 10:55:58 pm »
Maybe ontop of this thing
Offline tsman
« Reply #4 on: April 08, 2019, 11:01:59 pm »
It is mechanism part 10 TENSION STUD BASE and 11 TENSION STUD. See attached. I've included a very fuzzy photo of another JVC VCR mechanism which you can see the plastic part.
Offline coromonadalix
« Reply #5 on: April 08, 2019, 11:04:13 pm »
part no 10  in the section 5.3  mechanism assembly M4 ??
tsman  got me  while writing this  loll
« Last Edit: April 08, 2019, 11:07:00 pm by coromonadalix »
Online Psi
« Reply #6 on: April 08, 2019, 11:07:05 pm »
Nice spotting!
  • EE meid in Itali
« Reply #7 on: April 09, 2019, 09:58:04 pm »
Little Bastard!
After some tiny drops of grease on some mechanical parts, some general cleaning with compress air and IPA everything works like expected.
tsman and coromonadalix PM me if you are coming to Munich, this
will be yours for free!
Thanks on the others too, for them just 0,5L for free.
« Last Edit: April 09, 2019, 10:04:10 pm by zucca »
