Hello, I've purchased this week on eBay a TDS540C which seems to work OK, pass the start self-test and SPC test.
However there is one failure I notice with cursor management: the H-bar work OK but the V-bar are not working properly.
The V-bar will never appear on the screen upon selection plus the display of its values (DELTA and ABSOLUTE) seems to be multiplied by 100x when comparing on the Horizontal scale time division.
If choosing the InstaVu then both V-bars appear on the screen and shows correct values.
Same failure under paired cursor who never show up on the display but will appear if choosing InstaVu mode.
Thank you, Albert
