Hi i got a DPO7254 on my bench, after starting up the unit, it fails with error 315 and 316. My debug logs are pointing to a demux communication problem.
my error looks like this:
File opened: Sat Jan 07 13:52:30 2023
EnablePowerupDiags = 1, puMode=User
DiagPowerUpDiagsEnabled = 1
Model: DPO7254
Serial number: B010315, HFD201[0] ID = 0 (0x000000)
Scope.exe Version: 5.3.5 Build 22; Sat Jan 07 13:52:41 2023: Executing Powerup diags ... Pu=24 T=27C
Test "111" - Processor-->Memory-->DRAMWalk1 started
Test execution time 9.7778e-006 sec
Test "112" - Processor-->Memory-->DRAMCell started
Test execution time 0.010838 sec
Test "113" - Processor-->Memory-->DRAMMarch started
Test execution time 0.0015251 sec
Test "114" - Processor-->Memory-->DRAMCal started
Test execution time 2.0394e-005 sec
Test "211" - Registers-->PCI-->MIA started
Test execution time 0.0056395 sec
Test "221" - Registers-->Acquisition-->ACL started
Test execution time 0.00019779 sec
Test "222" - Registers-->Acquisition-->PLL started
Test execution time 0.020034 sec
Test "223" - Registers-->Acquisition-->Preamp started
Test execution time 0.0067425 sec
Test "224" - Registers-->Acquisition-->TrkHld started
Test execution time 0.0040994 sec
Test "225" - Registers-->Acquisition-->ADC started
Test execution time 0.023456 sec
Test "226" - Registers-->Acquisition-->DAC started
Test execution time 0.005549 sec
Test "227" - Registers-->Acquisition-->Demux started
Test execution time 0.0040382 sec
Test "231" - Registers-->Trigger-->SBTL started
Test execution time 8.7721e-005 sec
Test "232" - Registers-->Trigger-->SGTL started
Test execution time 0.0067855 sec
Test "233" - Registers-->Trigger-->TrigComp started
Test execution time 9.3587e-005 sec
Test "234" - Registers-->Trigger-->CommTrig started
Test execution time 0.034591 sec
Test "235" - Registers-->Trigger-->FTL started
*** TEST N/A FOR THIS HW ***
Test execution time 1.9556e-006 sec
Test "241" - Registers-->Misc-->FanCtrl started
Test execution time 1.6762e-006 sec
Test "242" - Registers-->Misc-->Tek04 started
Test "243" - Registers-->Misc-->DigCtrl started
Test "244" - Registers-->Misc-->IntfBoard started
Test "245" - Registers-->Misc-->FpBoard started
Test "246" - Registers-->Misc-->AfeBoard started
Test "252" - Registers-->DigitalTrig-->Tek05Dev started
Test "253" - Registers-->DigitalTrig-->Tek05HKRam started
Test "254" - Registers-->DigitalTrig-->Tek05AcqRam started
Test "311" - Acquisition-->Demux-->RunAB started
Test execution time 0.28398 sec
Test "312" - Acquisition-->Demux-->AcqDone started
Test execution time 0.0016488 sec
Test "313" - Acquisition-->Demux-->SysRdy started
Test execution time 0.0015136 sec
Test "314" - Acquisition-->Demux-->Interrupt started
Test execution time 0.0014753 sec
Test "315" - Acquisition-->Demux-->IdcLoSpeed started
Error from DEMUX3 to DEMUX4 expect: 000037fe rcv: 00003f56
Error from DEMUX3 to DEMUX4 expect: 000037fd rcv: 00003f55
Error from DEMUX3 to DEMUX4 expect: 000037fb rcv: 00003f53
Error from DEMUX3 to DEMUX4 expect: 000037f7 rcv: 00003f57
Error from DEMUX3 to DEMUX4 expect: 000037ef rcv: 00003f47
Error from DEMUX3 to DEMUX4 expect: 000037df rcv: 00003f57
Error from DEMUX3 to DEMUX4 expect: 000037bf rcv: 00003f17
Error from DEMUX3 to DEMUX4 expect: 0000377f rcv: 00003f57
Error from DEMUX3 to DEMUX4 expect: 000036ff rcv: 00003e57
Error from DEMUX3 to DEMUX4 expect: 000035ff rcv: 00003d57
Error from DEMUX3 to DEMUX4 expect: 000033ff rcv: 00003b57
Error from DEMUX3 to DEMUX4 expect: 00003fff rcv: 00003f57
Error from DEMUX3 to DEMUX4 expect: 000027ff rcv: 00002f57
Error from DEMUX3 to DEMUX4 expect: 000017ff rcv: 00001f57
Error from DEMUX3 to DEMUX4 expect: 000037ff rcv: 00003f57
Test diagIdcLoSpeedRunTest TransmitRight - WalkZeros FAILED
Error from DEMUX3 to DEMUX4 expect: 00000808 rcv: 00000800
Error from DEMUX3 to DEMUX4 expect: 00000820 rcv: 00000800
Error from DEMUX3 to DEMUX4 expect: 00000880 rcv: 00000800
Error from DEMUX3 to DEMUX4 expect: 00000000 rcv: 00000800
Test diagIdcLoSpeedRunTest TransmitRight - WalkOnes FAILED
Error from DEMUX4 to DEMUX3 expect: 000037fe rcv: 00003f56
Error from DEMUX4 to DEMUX3 expect: 000037fd rcv: 00003f55
Error from DEMUX4 to DEMUX3 expect: 000037fb rcv: 00003f53
Error from DEMUX4 to DEMUX3 expect: 000037f7 rcv: 00003f57
Error from DEMUX4 to DEMUX3 expect: 000037ef rcv: 00003f47
Error from DEMUX4 to DEMUX3 expect: 000037df rcv: 00003f57
Error from DEMUX4 to DEMUX3 expect: 000037bf rcv: 00003f17
Error from DEMUX4 to DEMUX3 expect: 0000377f rcv: 00003f57
Error from DEMUX4 to DEMUX3 expect: 000036ff rcv: 00003e57
Error from DEMUX4 to DEMUX3 expect: 000035ff rcv: 00003d57
Error from DEMUX4 to DEMUX3 expect: 000033ff rcv: 00003b57
Error from DEMUX4 to DEMUX3 expect: 00003fff rcv: 00003f57
Error from DEMUX4 to DEMUX3 expect: 000027ff rcv: 00002f57
Error from DEMUX4 to DEMUX3 expect: 000017ff rcv: 00001f57
Error from DEMUX4 to DEMUX3 expect: 000037ff rcv: 00003f57
Test diagIdcLoSpeedRunTest TransmitLeft - WalkZeros FAILED
Error from DEMUX4 to DEMUX3 expect: 00000808 rcv: 00000800
Error from DEMUX4 to DEMUX3 expect: 00000820 rcv: 00000800
Error from DEMUX4 to DEMUX3 expect: 00000880 rcv: 00000800
Error from DEMUX4 to DEMUX3 expect: 00000000 rcv: 00000800
Test diagIdcLoSpeedRunTest TransmitLeft - WalkOnes FAILED
IDC Low Speed test FAILED
diagIdcLoSpeed error summary of failing demux pairs:
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
*** TEST FAILED ***
Test execution time 0.020886 sec
diagMgr:diagLogFailure: Sat Jan 07 13:52:41 2023 P Pu=24 T=27 "diagIdcLoSpeed FAILED"
Test "316" - Acquisition-->Demux-->IdcHiSpeed started
Error from DEMUX3 to DEMUX4 expect: ffff7ffe rcv: ffff7f7e
Error from DEMUX3 to DEMUX4 expect: fffefffd rcv: ff7eff7d
Error from DEMUX3 to DEMUX4 expect: fff7ffef rcv: ff77ff6f
Error from DEMUX3 to DEMUX4 expect: ffdfffbf rcv: ff5fff3f
Error from DEMUX3 to DEMUX4 expect: 00400080 rcv: 00400000
Error from DEMUX3 to DEMUX4 expect: fefffdff rcv: fe7ffd7f
Error from DEMUX3 to DEMUX4 expect: f7ffefff rcv: 77ffefff
Error from DEMUX3 to DEMUX4 expect: dfffbfff rcv: 5fffbfff
Error from DEMUX3 to DEMUX4 expect: bfff7fff rcv: bfff7f7f
Test FAILED
Error from DEMUX4 to DEMUX3 expect: ffff7ffe rcv: ffff7f7e
Error from DEMUX4 to DEMUX3 expect: fffefffd rcv: 7f7e7f7d
Error from DEMUX4 to DEMUX3 expect: fffdfffb rcv: 7f7d7f7b
Error from DEMUX4 to DEMUX3 expect: fffbfff7 rcv: 7f7b7f77
Error from DEMUX4 to DEMUX3 expect: fff7ffef rcv: 7f777f6f
Error from DEMUX4 to DEMUX3 expect: ffefffdf rcv: 7f6f7f5f
Error from DEMUX4 to DEMUX3 expect: ffdfffbf rcv: 7f5f7f3f
Error from DEMUX4 to DEMUX3 expect: 00400080 rcv: 00400000
Error from DEMUX4 to DEMUX3 expect: ff7ffeff rcv: ff7f7e7f
Error from DEMUX4 to DEMUX3 expect: fefffdff rcv: 7e7f7d7f
Error from DEMUX4 to DEMUX3 expect: fdfffbff rcv: 7d7f7b7f
Error from DEMUX4 to DEMUX3 expect: fbfff7ff rcv: 7b7f777f
Error from DEMUX4 to DEMUX3 expect: f7ffefff rcv: 777f6f7f
Error from DEMUX4 to DEMUX3 expect: efffdfff rcv: 6f7f5f7f
Error from DEMUX4 to DEMUX3 expect: dfffbfff rcv: 5f7f3f7f
Error from DEMUX4 to DEMUX3 expect: bfff7fff rcv: bfff7f7f
Test FAILED
diagIdcHiSpeed error summary of failing demux pairs:
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
Retrying tstDiagIdcHiSpeed test ... T=27C
Error from DEMUX3 to DEMUX4 expect: fff7ffef rcv: ff77ffef
Error from DEMUX3 to DEMUX4 expect: fdfffbff rcv: fd7ffbff
Error from DEMUX3 to DEMUX4 expect: f7ffefff rcv: f77fef7f
Test FAILED
Test FAILED
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
*** TEST FAILED ***
Test execution time 0.56149 sec
diagMgr:diagLogFailure: Sat Jan 07 13:52:41 2023 P Pu=24 T=27 "diagIdcHiSpeed FAILED"
Test "317" - Acquisition-->Demux-->IdcAcqDataXfr started
Test skipped because Demux IDC tests failed.
*** TEST NOT RUN YET ***
Test execution time 0.0001841 sec
Test "318" - Acquisition-->Demux-->IdcDispDataXfr started
Test execution time 0.00015449 sec
Test "321" - Acquisition-->Dma-->PaDma started
Test execution time 0.00017349 sec
Test "322" - Acquisition-->Dma-->IdcAcqDma started
Test execution time 0.00035591 sec
Test "331" - Acquisition-->Memory-->MemData started
Test execution time 0.020599 sec
Test "332" - Acquisition-->Memory-->MemAddr started
Test execution time 0.0038114 sec
Test "342" - Acquisition-->Vertical-->TH Inputs started
Test execution time 0.30105 sec
Test "345" - Acquisition-->Vertical-->50ohmOvld started
Test execution time 0.90188 sec
Test "351" - Acquisition-->PLL-->Clock Freq started
Test execution time 0.65833 sec
Test "371" - Acquisition-->AcqProcessor-->SPI started
Test execution time 0.00016874 sec
Test "372" - Acquisition-->AcqProcessor-->INT Line started
Test execution time 0.00069087 sec
Test "373" - Acquisition-->AcqProcessor-->Interrupt started
Test execution time 0.00099873 sec
Test "374" - Acquisition-->AcqProcessor-->RelayDrive started
Test execution time 3.073e-006 sec
Test "375" - Acquisition-->AcqProcessor-->TWI started
Test execution time 0.00013102 sec
Test "376" - Acquisition-->AcqProcessor-->PrbInterrupts started
Test execution time 0.00036317 sec
Test "377" - Acquisition-->AcqProcessor-->TCpowerCtrl started
Test "378" - Acquisition-->AcqProcessor-->MAX517 started
Test execution time 0.00093978 sec
Test "411" - Trigger-->Inputs-->Ch1 started
Test execution time 0.14072 sec
Test "412" - Trigger-->Inputs-->Ch2 started
Test execution time 0.13072 sec
Test "413" - Trigger-->Inputs-->Ch3 started
Test execution time 0.13071 sec
Test "414" - Trigger-->Inputs-->Ch4 started
Test execution time 0.1307 sec
Test "415" - Trigger-->Inputs-->Line started
Test execution time 0.014745 sec
Test "416" - Trigger-->Inputs-->Video started
Test execution time 0.21615 sec
Test "417" - Trigger-->Inputs-->Events started
Test execution time 0.22039 sec
Test "418" - Trigger-->Inputs-->Serial started
Test execution time 0.3515 sec
Test "419" - Trigger-->Inputs-->HSMeta started
Test execution time 2.2349e-006 sec
Test "421" - Trigger-->Outputs-->523TrgOut started
Test execution time 0.00050565 sec
Test "422" - Trigger-->Outputs-->523CpuInt started
Test execution time 0.00047324 sec
Test "423" - Trigger-->Outputs-->Fedge started
Test execution time 0.043754 sec
Test "424" - Trigger-->Outputs-->Ftrig started
Test execution time 0.043379 sec
Test "441" - Trigger-->Word-->Compare started
Test execution time 2.5143e-006 sec
Test "442" - Trigger-->Word-->Delay started
Test "443" - Trigger-->Word-->Clk Qualify started
Test "444" - Trigger-->Word-->Formed LSST started
Test "451" - Trigger-->Digital-->Acq started
Sat Jan 07 13:52:46 2023: USER MODE POWERUP DIAGNOSTICS RESULTS: 22 (of 67) tests SKIPPED
Sat Jan 07 13:52:46 2023: USER MODE POWERUP DIAGNOSTICS RESULTS: 2 (of 45) EXECUTED tests FAILED
Processor Failures: 0
Registers Failures: 0
Acquisition Failures: 2
Trigger Failures: 0
TekLink Failures: 0
Test 315 - F ==> Acquisition->Demux->IdcLoSpeed, 0.020886 sec
Test 316 - F ==> Acquisition->Demux->IdcHiSpeed, 0.56149 sec
13:52:46:048[2336] diagMgr.cpp:calDiagManager(948) Powerup diags finished in 4.9161 sec
<< POWERUP DIAGS FINISHED >>
Sat Jan 07 14:10:05 2023: DIAGNOSTIC EXECUTION starting ... Pu=24 T=31C
Test execution time 0.30136 sec
Test execution time 0.0016745 sec
Test execution time 0.0012745 sec
Test execution time 0.0031004 sec
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
*** TEST FAILED ***
Test execution time 0.013694 sec
diagMgr:diagLogFailure: Sat Jan 07 14:10:05 2023 D Pu=24 T=31 "diagIdcLoSpeed FAILED"
Error from DEMUX3 to DEMUX4 expect: 00008001 rcv: 2828a829
Error from DEMUX3 to DEMUX4 expect: 00010002 rcv: 2829282a
Error from DEMUX3 to DEMUX4 expect: 00020004 rcv: 282a282c
Error from DEMUX3 to DEMUX4 expect: 00040008 rcv: 20242028
Error from DEMUX3 to DEMUX4 expect: fffbfff7 rcv: fffbffff
Error from DEMUX3 to DEMUX4 expect: 00080010 rcv: 20282838
Error from DEMUX3 to DEMUX4 expect: 00100020 rcv: 08180828
Error from DEMUX3 to DEMUX4 expect: ffefffdf rcv: ffefffff
Error from DEMUX3 to DEMUX4 expect: 00200040 rcv: 08282868
Error from DEMUX3 to DEMUX4 expect: 00400080 rcv: 286828a8
Error from DEMUX3 to DEMUX4 expect: 00800100 rcv: 28a82928
Error from DEMUX3 to DEMUX4 expect: 01000200 rcv: 29282a28
Error from DEMUX3 to DEMUX4 expect: 02000400 rcv: 2a282c28
Error from DEMUX3 to DEMUX4 expect: 04000800 rcv: 24202828
Error from DEMUX3 to DEMUX4 expect: 08001000 rcv: 28283828
Error from DEMUX3 to DEMUX4 expect: 10002000 rcv: 18082828
Error from DEMUX3 to DEMUX4 expect: 20004000 rcv: 28286828
Error from DEMUX3 to DEMUX4 expect: 40008000 rcv: 6828a828
Test FAILED
Test FAILED
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
Retrying tstDiagIdcHiSpeed test ... T=31C
Test FAILED
Test FAILED
DEMUX3 --> DEMUX4
DEMUX4 --> DEMUX3
*** TEST FAILED ***
Test execution time 0.56268 sec
diagMgr:diagLogFailure: Sat Jan 07 14:10:05 2023 D Pu=24 T=31 "diagIdcHiSpeed FAILED"
Test execution time 0.00020058 sec
Test execution time 0.00024277 sec
Sat Jan 07 14:10:06 2023: DIAG MODE DIAGNOSTICS RESULTS: 2 (of 8) tests SKIPPED
Sat Jan 07 14:10:06 2023: DIAG MODE DIAGNOSTICS RESULTS: 2 (of 6) EXECUTED tests FAILED
Test 315 - F ==> Acquisition->Demux->IdcLoSpeed, 0.013694 sec
Test 316 - F ==> Acquisition->Demux->IdcHiSpeed, 0.56268 sec
DIAGNOSTIC EXECUTION finished in 0.94508 sec
anybody have any experience in reflowing / reballing these guys without damaging the board or tracks below?
