Hi All,
Recently aquired a Sega Dreamcast, I got it given to me becasue it's broken. Upon first inspection the console turns on, screen stays black for a little while, then the dreamcast logo appears, it then stays on this for a few minutes, before loading the dashboard and displaying "Please wait while disc is being checked". This is all it does, this message doesn't go away and I am unable to browse the menu or do anything else. Even the time doesn't change, it's like the system has crashed.
Looking at the console it has been opened before, upon opening it I found screws missing on the laser unit and control ports. The fixed lithium battery had been replaced with a holder, the holder contained at CR3020, not the rechargable kind. So I removed that as I believe the Dreamcast battery recharges. I tested the controller fuse, this is intact.
The laser unit wasn't behaving normally when searching, so I tested the cables and found the ribbon cable had a damaged trace, repaired that and now it seems to be acting like it should. Before fixing the ribbon, holding down the lid switch it would spin up the disc and stop. Now it spins up, searches the disc and continues spinning. It also looks like someone resoldered the lid switch. The switch appears to be functioning normally as when I press it the laser unit starts working and when I release it, it stops straight away.
Upon booting the system with no battery and fixed ribbon, it still shows no output for a short while and then stays on the dreamcast logo for a few minutes, but then asked me to set the time, which I can do with no problems. Once I hit select to continue, it goes to the dash and displays the same message and I am unable to do anything again.
At this point I have run out of ideas, not sure if its hardware or software. Visually inspecting the rest of the system, looks like the motherbaord has never been accessed before and the psu output is testing fine.
Any help would be appreciated.
Regards
Rob.
