Author Topic: Dremel 3000 not working (switch)  (Read 4460 times)
Offline cHopsTopic starter
« on: December 11, 2014, 06:12:46 pm »
Hello,
I am having issues with my dremel. It is fairly new, however, the machine no longer turns on (at any variable speed level). I opened it up and i think I discovered the problem. I have done some research and have seen that this model dremel (the 3000) has issues with the switch. I am not an expert in electronics but I am pretty sure that what I found is not right. Check the picture that goes along with this post.
I saw a post with a similar issue and the person replying suggested two parts, however i am not sure which one i need. The page that sells the parts is a bit ambiguous in the product description (there is none).
Here are the links:
http://www.ereplacementparts.com/search_result.php?ssq=1&categories_id=15440&products_class_id=85&dsk=1
http://www.ereplacementparts.com/dremel-3000-rotary-tool-parts-c-15440_15456_205856.html
Anyways, let me know what you guys think.
Thanks,
cHops
Offline ivan747
Re: Dremel 3000 not working (switch)
« Reply #1 on: December 12, 2014, 01:32:54 am »
Is it under warranty? That's a manufacturing defect in my books.
Offline DmitryL
« Reply #2 on: December 12, 2014, 11:22:21 am »
Hello,
Looks like burnt resistor. I think, that if the motor itself is OK, you can short the regulator and use external one, any triac-dimmer will do.
« Reply #3 on: December 12, 2014, 01:41:12 pm »
Yes it is under warranty, but rather than spending the money and time on shipping it to them for them to tell me that they cant fix it, I would rather buy the part if it is a cheap fix.
What about links to the replacement parts that i posted? Would any of those work for this?
Thanks
cHops
