Hello, how are you?
Does anyone have any idea what to check on a Vacon variable speed drive with a system 8 fault ID 603, which says that the auxiliary voltage is too low? I have already checked the voltage at 24 volts and it is ok. The manual does not indicate much, thank you
200 hp 480v VFD
regards
