I need some help from either someone who can extract a working vxworks image from this firmware file or someone who can provide the files from a working device.
I tried different things now loading the vxworks ELF images i extracted manually from the firmware file and the ones emba extracted automaticly. I tried to load it in u-boot using loady and ymodem in minicom but could not get it to work.
I then tried it using kermit in minicom and was able to successfully upload the data using ckermit after creating ~/.kermrc with this content:
set carrier-watch off
set handshake none
set flow-control none
robust
set file type bin
set rec pack 1000
set send pack 1000
set window 5
I tried the firmware file itself and the extracted ELF files from the firmware file containing the vxworks stuff. The firmware file has more than 50 MB. It took more than 90 minutes to upload it over uart serial connection in u-boot. I't didn't help. When i run
go 0x20000000
and some commands from printenv data like
td_bootargs_confab; run flashload_g0; bootvx 0x20000000
It always complains "No ELF file at 0x20000000". Because of the very slow upload speed using kermit, i tried a combination of Marvell u-boot shell and openocd.
Loading a file to memory is way faster in openocd.
I started the device, pressed a button to stop boot process and entering the Marvell u-boot shell. In openocd i did:
halt
load_image /home/<user>/<some_path>/7698614-19018234.elf32 0x20000000 elf
resume
In u-boot i tried the same commands like before, go 0x20000000 or td_bootargs_confab; run flashload_g0; bootvx 0x20000000.
I don't know why but sometimes the image was not loaded to 0x20000000. Sometimes it was loaded at 0x21000000.
I couldn't even load the original vxworks image i dumped from the Drobo device.
One time i tried loading it at 0x00000000 and it was loaded at 0x01000000.
In this case, i did in openocd a resume 0x01000000 and to my surprise, it started to load but halted at some point.
But this time i had blue lights on the device and the bootlog was different:
Marvell>> td_bootargs_confab; run flashload_g0; bootvx 0x21000000
Env Var skipConfabulation=0
Skip Confabulation: NONE
... skipConfabulation: 0x1 skips Vx confab, 0x2 skips Lx confab
Current Value of Vx bootargs_g0:
bootargs_g0=neta(3,0) f=0x6000 o=usb0:eth3:cpus=1:mem=0x20000000;MAC3-00:50:43:11:89:dd;SEe
EnvVar bootargsStart=neta(3,0)
EnvVar vxFlags=f=0x6000
EnvVar vxDev=usb0:eth3:cpus=1:mem=0x20000000
EnvVar eth3addr=00:50:43:11:89:dd
EnvVar droboSER=DRB143602000000
EnvVar vxCmd=s=#/romfs/runesa.vxe
Confabulated Value of bootargs_g0:
Current bootargs_g0 perfectly match the Confabulated bootargs_g0
No Need to Update the Environment
reading vxWorks_prev
17734472 bytes read
## Ethernet MAC address not copied to NV RAM
## No elf image at address 0x21000000
## Not an ELF image, assuming binary
## Using bootline (@ 0x1100): neta(3,0) f=0x6000 o=usb0:eth3:cpus=1:mem=0x20000000;MAC3-00e
## Starting vxWorks at 0x21000000 ...
MPP33 Config (0xd0018010) == 0x11110040 (Should be: 0xXXXXXX4X)
SDRAM Config (0xd0001400) == 0x7201c924 (Should be: 0x72XXXXXX)
DRAM TBsAddr (0xd0001580) == 0x20000000 (Should be: 0x??????]
Booting from CPU 0
Detected board Heatwave 1.0
DRAM env init....... Done.
Detected DRAM size 512MB
AMP: Resources - uart0 - pex1 - pex2 - eth3 - xor0 - usb0 - i2c0 - i2c1 - sata - spi - g
AMP CPUs = 1
AMP mem size = 0x20000000
TWSI init Channel 0....... Done. Actual freq = 97656Hz
Skipping serdes configuration.
Ctrl env init....... Done.
Addr Dec Win......
Verified
CP15 mrvl dbgr 0x000109A7
CP15 mrvl dbgr2 0xEA008208
CP15 mrvl ctrl 0x000001B6
CPU if init......... Done.
GPP init............ Done.
Using DRAM size 512MB
=======================> HW Revision Register == 0x00000881
Detected Board: Heatwave MVT, Spin 0 (No EthDebug)
Detect: Tclk 250MHz
SysClk 600MHz
L2Clk 600MHz
pClk 1200MHz
Marvell Controller initialization Done.
Modules Detected:
SPI flash based addr on 0xD4000000=
SPI Flash 8MB detected
esaXORSystemInit
esaXORSystemInit...done
esaDMASystemInit
Initialising SEEPROM Interface
Checking Bootline.......0x00001100 [0x6e]
UBOOT Version: UBOOT-2.33
Bootline params = neta(3,0) f=0x6000 o=usb0:eth3:cpus=1:mem=0x20000000;MAC3-00:50:43:11:89
DRAM int Ctrl....... Done
IDMA Err int Ctrl... Done
IDMA init........... Done
NETA Err int Ctrl... Done
Neta int Ctrl....... Done
GPIO int Ctrl....... Done
PCI int Ctrl........ Done
PCI-E 0: Not mapped to this OS
PCI-E 1: Not mapped to this OS
PCI-E 2: Not mapped to this OS
PCI-E 3: Not mapped to this OS
mvPexIntfInit() ROOT COMPLEX Init pexHWInf: 4
mvSysPexInit() called pexIf: 4 type: 0 MAX_TARGETS: 44
mvSysPexInit() OK from mvCtrlAddrWinMapBuild()
mvSysPexInit() OK from mvPexWinInit()
mvPexModeGet() configured as ROOT reg: 0x4014032e
mvPexInit() configuring as ROOT
mvPexLocalBusNumSet() called for pexIf: 4 busNum: 0 localBus: 0 localDev: 0
*******************mvPexLocalDevNumSet(4) localBus: 0 localDev: 0 pexStatus: 0 ***********
mvPexInit() call mvPexMasterEnable
mvPexInit() call mvPexSlaveEnable
mvPexInit() disable int
mvPexInit() wait a tick
mvPexInit() check for link
PEX4 interface detected Link X1
mvPexIntfInit() checking if we should set the localBus pex0flg: 0 pexHWInf: 4
mvPexIntfInit() setting localBusNum to 0 for pexHWInf 4
PCI-E 4/10: Done.
PCI-E 5: is power off
mvPexIntfInit() ROOT COMPLEX Init pexHWInf: 6
mvSysPexInit() called pexIf: 6 type: 0 MAX_TARGETS: 44
mvPexModeGet() configured as ROOT reg: 0x4014022e
mvPexLocalBusNumSet() called for pexIf: 6 busNum: 0 localBus: 1 localDev: 0
*******************mvPexLocalDevNumSet(6) localBus: 0 localDev: 0 pexStatus: 0 ***********
PEX6 interface detected Link X1
mvPexIntfInit() checking if we should set the localBus pex0flg: 0 pexHWInf: 6
mvPexIntfInit() setting localBusNum to 0 for pexHWInf 6
mvPexLocalBusNumSet() called for pexIf: 6 busNum: 0 localBus: 0 localDev: 0
PCI-E 6/10: Done.
mvPexIntfInit() ROOT COMPLEX Init pexHWInf: 7
mvSysPexInit() called pexIf: 7 type: 0 MAX_TARGETS: 44
mvPexLocalBusNumSet() called for pexIf: 7 busNum: 0 localBus: 2 localDev: 0
*******************mvPexLocalDevNumSet(7) localBus: 0 localDev: 0 pexStatus: 0 ***********
PEX7 interface detected Link X1
mvPexIntfInit() checking if we should set the localBus pex0flg: 0 pexHWInf: 7
mvPexIntfInit() setting localBusNum to 0 for pexHWInf 7
mvPexLocalBusNumSet() called for pexIf: 7 busNum: 0 localBus: 0 localDev: 0
PCI-E 7/10: Done.
mvPexIntfInit() ROOT COMPLEX Init pexHWInf: 8
mvSysPexInit() called pexIf: 8 type: 0 MAX_TARGETS: 44
mvPexLocalBusNumSet() called for pexIf: 8 busNum: 0 localBus: 3 localDev: 0
*******************mvPexLocalDevNumSet(8) localBus: 0 localDev: 0 pexStatus: 0 ***********
PEX8 interface detected Link X1
mvPexIntfInit() checking if we should set the localBus pex0flg: 0 pexHWInf: 8
mvPexIntfInit() setting localBusNum to 0 for pexHWInf 8
mvPexLocalBusNumSet() called for pexIf: 8 busNum: 0 localBus: 0 localDev: 0
PCI-E 8/10: Done.
PCI-E 9: Not mapped to this OS
USB0 init........... Done. HOST type selected
USB Err int Ctrl.... Done
XOR Err int Ctrl.... Done
mvSysXorInit: done
XOR init............ Done
mvCtrlInit2......... done
vxbDevInit.........done
sysSerialConnectAll.........done
Serial Ports...Attached
UART2...Baud Rate Adjusted to 38.4K
VxBus Loaded.... done
bspConfigureI2CTable: Configuring I2C tables for 8-Slot (Kryten)
[tRootTask] 1970-01-01 00:00:00: drDrvLaunch
---->> drDrv() <<----
Allocated temp buffer 0x42599a8
[tRootTask] 1970-01-01 00:00:00: Diagnostic Re-Route Device Driver - Version 1.0 - Install.
[tRootTask] 1970-01-01 00:00:00: drStartLogging() started
_DEF_STD_OUT = 3 _DEF_STD_ERR = 3 _DR_FD = 4
Host Name: bootHost
Target Name: vxTarget
User: target
Ethernet port #3 initialized
neta3 Interface Loaded; MAC: 00:50:43:11:89:DD
neta3 Interface Started
Attempting to register custom syscalls group
ipAttached to interface neta3 ip=
Can't Set IP address to <neta3> interface..bootline does not have ethernet ipAddress
Adding 10511 symbols for standalone.
Detected Marvell USB. SettingwdbConfig: error configuring WDB communication interface
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks 6.8
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.13
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-2012
CPU: Marvell Sheeva 88SV584x, Board= Heatwave 1.0 ARMARCHV7 LE core. Processor #0.
Memory Size: 0x1fe70000. BSP version 2.3.1.
Created: Feb 3 2016, 20:45:55
ED&R Policy Mode: Deployed
WDB Comm Type: WDB_COMM_END
WDB: Agent configuration failed.
[tRootTask] 1970-01-01 00:00: MV_USB_MODE_RE00: kCmdInit: Initialising kernel command liner
[tRootTask] 1970-01-01 00:00:00: diskCmdRegister: Installing k disk Commands
G = 0x3
ESA Register Driver Found Board version 2, stuffing option 1
Initialising boot SEEPROM handler
Checking boot register values in serialEEPROM ...
<<<<Flash Upgrade Driver - version 1.0 - installed.
IsFlashForDroboPro: We are NOT running on Drobo Pro deal with flash accordingly
Failed to get flash layout...this is expected for Optimus Prime, which does not have NOR F.
System Configuration
CHIP : MV88F7846 Rev 2
CPU : Marvell PJ4B (584) v7 (Rev 2)
BOARD : Heatwave 1.0 (0x0)
CLOCKs : tClk = 250MHz, sysClk = 600MHz
L2Clk = 600MHz pClk = 1200MHz
ETH_JUMBO_SUPPORT = Disabled
BRIDGING_SUPPORT = Enabled
MULTI_Q_SUPPORT = Disabled
NAT_SUPPORT = Disabled
VFP_SUPPORT = Enabled
L2 Cache = Enabled
IO coherency = Enabled
Get DATE: 2071-06-19 (Friday) TIME: 21:30:01
[vxWorks *]#
Board Type 4, Rev 2 (Heatwave MVT), Spin = 0
Stuffing Opt = 1 (No EthDebug), DevDebugBitz = 0x0
Drobo B810i
Heatwave
Ready to take a Byte!
Initializing PMU...
Reading PMU Version...
PMU Version: 1.2.0x046c, Download Version 108 (Variant 4) [Failsafe Ver 4]
Considering an Update to the PMU ...
PMU is up to date for this MVT board.
Reading 0xac from PMU GPIO Port 1 [ @0x0020 ]
Reading 0xef from PMU GPIO Port 2 [ @0x0028 ]
Reading 0x71 from PMU GPIO Port 3 [ @0x0018 ]
Reading 0x10 from PMU GPIO Port 4 [ @0x001c ]
PMU is Running on AC Power :-)
0x48ac278 (BusM A): 0x48ac278 (BusM A): INFO: usb2Msc - Storage driver got a device attach.
INFO: usb2Msc - Storage driver got a device attach notification.
This Optimus Prime PMU is NOT configured for Early-Follow of DDR3 Reset...Fixing
0x48ac278 (BusM A): 0x48ac278 (BusM A): INFO: usb2Msc - Mounting device (PDT 0x0 PQ 0x0 RMP
INFO: usb2Msc - Mounting device (PDT 0x0 PQ 0x0 RMB 0x0) VID = : PID = USB DISK MP
0x48ac278 (BusM A): 0x48ac278 (BusM A): INFO: usb2Msc - Device 0x2 LUN 0 of 1005568 (KB) w0
INFO: usb2Msc - Device 0x2 LUN 0 of 1005568 (KB) will be mounted with base name /bd0
This Optimus Prime Board Supports Self-Refresh only with VRM_EN
...PMU will ENABLE VRM_EN during a reboot/shutdown cycle.
PMU BootOnBatt Counter DEFAULT is now 3
/bd0/ - disk check in progress ...
/bd0/Crashlogs/crashlog-20160306-1012 PMU BootOnBatt Counter ACTUAL is now 3
Set temp = Kryten
/bd0/ - Volume is OK
total # of clusters: 62,580
# of free clusters: 56,607
# of bad clusters: 0
total free space: 905,712 Kb
0, 0, max contiguous free space: 923,697,152 bytes
# of files: 58
# of folders: 1
total bytes in files: 94,805 Kb
# of lost chains: 0
total bytes in lost chains: 0
0, 0, 0, 0,
PMU Skip-OverTemp Setting: 0x0000
PMU Shutdown Status: 0x00
PMU Shutdown IS NOT Pending!
PMU Shutdown Reasons are Fully Enabled
Disk Array Temp is Within Tolerances
CPU Core Temp is Within Tolerances
PMU Core Temp is Within Tolerances
PMU Shutdown Reason: 0x00
PMUCmd: "A" --> "a"
"Y" --> "0x0680,23:20.75,0,0,0"
"B" --> "1,0,0,0,0,1"
Total = 0:0 in 0 cycles
PMU state machine current state is 'NORMAL' [0x06]
PMU reports the DRAM data was INVALID at bootup [0x80]
Accumulated Up-time = 0 days: 0 hours: 23 minutes: 20.085 seconds
(1 Active cycles, 1 Power cycles)
Latest battery backup time = 00:00:00 (hh:mm:ss)
Longest battery backup time = 00:00:00 (hh:mm:ss)
Accumulated battery backup time = 00:00:00 (hh:mm:ss)
(0 Backup cycles, 0 Completed cycles, 0 Failed cycles, 0 Backup flags)
0x4011744 (tErfTask): 0x4011744 (tErfTask): INFO: usb2Msc - Device /bd0 has been claimed bm
INFO: usb2Msc - Device /bd0 has been claimed by filesystem
NOTIFY: hDevice 0x2 lun 0 medium changed (mediumInsert = 1)
PMU Reports Voltages: (AC == 12.085V) (Batt == 0.263V)
PMU LED Dimming: Default==25, Current==25
PMU Fan Speed AutoAdjust has been ENABLED
PMU Fan Speed: Default== 1, Current== 1
Setting Temperature Critical Threshold for Disk from 56 to 65
Temperature Thresholds for Disk: Interest== 52, Warning== 55, Critical== 65 -- Override==F
PMU Init Done
**** ArmadaXP is Type B0
Launching LED Sequencer...
LED Sequencer...Launched
LED Sequencer...Testing...
Setup Kernel/RTP Messaging Interface
Initialising kernel<->RTP queues with 80 entries
USB command/response Q's @ 0xf4102000/0xf4103000
MULTI ISSUE command/response Q's @ 0x0/0xf4105000
FAST PATH QUEUING RTP INTERFACE ENABLED
64-BIT HOST LBAs ENABLED
Setup Kernel/RTP Resource Release Messaging Interface
Initialising kernel<->RTP resource release queues with 80 entries
MULTI ISSUE RESOURCE RELEASE Q @ 0xf4107000
FAST PATH QUEUING RTP RESOURCE RELEASE INTERFACE ENABLED
IntConnect pISR==0x01076b9c was Successful for Cause==32 ("PMU Panic")
IntConnect pISR==0x01076c34 was Successful for Cause==40 ("PMU PowerDownReq")
IntConnect pISR==0x01076b20 was Successful for Cause==57 ("PMU OverTemp")
IntConnect pISR==0x01076d48 was Successful for Cause==29 ("Disk Detected")
IntDisable for Cause==65 ("Clear Disk Button")
***** Initializing the Kernel's Thermal Monitor *****
***** Spawning the Kernel's Thermal Monitor *****
***** Executing Auxilliary Task for the Kernel's Thermal Monitor *****
KERNEL BOOTUP: usrAppInit: INFO: bootup with backup battery OFF
Not Turning the battery ON ye
PMUCmd: "~55" --> "~55!"
PMUCmd: "K" --> "k"
Intercore Access Device Driver - Version 1.0 - Installed.
Heatwave MVT Init Compleat!
[tRootTask] 2071-06-19 21:30:04: diskInterfaceInitialise: Starting Disk Driver(s) Initiali.
[tRootTask] 2071-06-19 21:30:04: bspDiskConfigureDiskTable: Configuring drive tables for 8e
[tRootTask] 2071-06-19 21:30:04: diskInterfaceInitialise: System has 8 slots
[tRootTask] 2071-06-19 21:30:04: diskDriverInstall:
[tRootTask] 2071-06-19 21:30:04: showDiskTbs: Dumping Disk Driver Config Tables:
[New Disk Thread] 2071-06-19 21:30:04: diskConfigureNewDiskThread: Starting thread
[tRootTask] 2071-06-19 21:30:04: Dumping Disk Adapter Table
[tRootTask] 2071-06-19 21:30:04: Adapter Instance Adapter Address Adapter Data Adds
[tRootTask] 2071-06-19 21:30:04: 0 0x01E59238 0x00000000
[tRootTask] 2071-06-19 21:30:04: 1 0x01E59238 0x00000000
[tRootTask] 2071-06-19 21:30:04: 2 0x01E59238 0x00000000
[tRootTask] 2071-06-19 21:30:04: 3 0x01E59238 0x00000000
[tRootTask] 2071-06-19 21:30:04: Dumping Disk Slot Config Table:
[tRootTask] 2071-06-19 21:30:04: Adapter Instance Connection Physical Slot Adapr
[tRootTask] 2071-06-19 21:30:04: 0 DRIVE 0 8
[tRootTask] 2071-06-19 21:30:04: 0 DRIVE 1 C
[tRootTask] 2071-06-19 21:30:04: 1 DRIVE 2 0
[tRootTask] 2071-06-19 21:30:04: 1 DRIVE 3 4
[tRootTask] 2071-06-19 21:30:04: 2 DRIVE 4 8
[tRootTask] 2071-06-19 21:30:04: 2 DRIVE 5 C
[tRootTask] 2071-06-19 21:30:04: 3 DRIVE 6 0
[tRootTask] 2071-06-19 21:30:04: 3 DRIVE 7 4
[tRootTask] 2071-06-19 21:30:04: diskInterfaceInitialise: Calling init with adapter 0 (0x0)
[tRootTask] 2071-06-19 21:30:04: ahciPerformPhyConfig: Loading phy regs for 9170
0x69cf2bMax Disk Temp: c
Data abort
Exception address: 0x010ca130
Current Processor Status Register: 0x80000013
Task: 0x69cf2bc "tRootTask"
(tRootTask): 0x69cf2bc (tRootTask): diskDriAhciStorageRegister:
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): diskDriAhciInstInit:
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): diskDriAhciInstInit2:
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): diskDriAhciInstInit2: Storing 0x04AE9148 to 0
diskDriAhciInstInit2: Storing 0x04AE9148 to adapter table entry 0
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): diskDriAhciInstConnect:
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): task 0x69cf2bc has had a failure and has bee.
task 0x69cf2bc has had a failure and has been stopped.
0x69cf2bc (tRootTask): 0x69cf2bc (tRootTask): fatal exception in a kernel task or stack ov!
fatal exception in a kernel task or stack overflow!
24 C, Ave Disk Temp: 23 C, Fan Speed = 1, Sampling Period = 36 sec
C, Slot 1: 23 C, Slot 2: 23 C, Slot 3: 24 C,
Slot 4: 24 C, Slot 5: 24 C, Slot 6: 24 C, Slot 7: 24 C,
CPU Core Temp: 55 C, PMU Core Temp = 33 C
Temperature Thresholds for CPU : Interest== 95, Warning==101, Critical==104 -- Override==F
Temperature Thresholds for PMU : Interest== 78, Warning== 82, Critical== 84 -- Override==F
It did not load the linux stuff. The device was not accessible and i had to reset the device in openocd using reset.
Reverseenginering the firmware flashing process or something like in the videos i mentioned above is way beyound my abilities.
So please let me know if you can provide files from a working device.
For now i will stop my experiments with this device.
