Author Topic: DS Lite.  (Read 3080 times)
Offline zerorisersTopic starter
  • young noobie, my apologies for low knowledge base.
DS Lite.
« on: August 09, 2014, 10:41:07 pm »
Hello everybody, zerorisers here.
I have an old nintendo DS Lite. problems that I have are that the pads for the power switch are lifted and the ribbon cable for the top lcd keeps shorting. Anything that I can do about either of these problems? (ribbon cables short because of wear and tear on the plastic coating I believe, so if I have it layed out in a particular way I can get a picture.)
Offline tautech
Re: DS Lite.
« Reply #1 on: August 10, 2014, 02:52:13 am »
Power switch could maybe bodged, is it momentary or off/on 2 position?
For the ribbon, chop up an old PC IDE HD cable for a replacement. Assuming it is for LV?
Offline wagon
Re: DS Lite.
« Reply #2 on: August 10, 2014, 05:20:50 am »
You can buy pretty much every part for the DS off Ebay.
Hiding from the missus, she doesn't understand.
Re: DS Lite.
« Reply #3 on: August 11, 2014, 02:41:03 pm »
Thank you both for the reply's, I don't have much money so I am attempting a cheaper alternative. This will be for personal use. The power switch in completely gone off the board.
Online wraper
  • Country: lv
Re: DS Lite.
« Reply #4 on: August 11, 2014, 03:05:21 pm »
If it has damaged insulation, then you can just put a piece of insulating tape on it. If it does not help, some conductor is broken.
Re: DS Lite.
« Reply #5 on: August 11, 2014, 03:07:15 pm »
Wraper seems to have had the best idea for me personally. I will try that and see how it works once I get the power going. I'm hoping once it is fixed I can make my own "game" for it and use if for email notifications and weather on my desk. :)
Re: DS Lite.
« Reply #6 on: August 11, 2014, 06:22:27 pm »
My apologies to tautech for not properly answering his question, it is a on/off switch I believe.
