Author Topic: GPIB-USB control between MacBook Air (Macintosh) and TDS540C  (Read 6975 times)
Offline TantratronTopic starter
  • Radio DSP Plasma
    • Tantratron
Re: GPIB-USB control between MacBook Air (Macintosh) and TDS540C
« Reply #25 on: January 02, 2020, 05:29:30 am »
Hello Ragnar,
I've another question which might know the answer since you operate a TDS6xx oscilloscope
Much before in this thread, I was mentioning 2 methods to enable some options (i.e. 2F) so this is some kind of hacking https://www.eevblog.com/forum/repair/gpib-usb-control-between-macbook-air-(macintosh)-and-tds540c/msg2839268/#msg2839268 which worked fine with my two TDS540C. Now I have FFT's, integral and derivate mathematics from my Oscope. I did try to some enabling-disabling options which are not dependent on HW and it works fine.
On some other threads, members state that we can flash or rewrite the NVRAM to obtain the same effect, namely to flip the bit value in charge of enabling the 2F option. The thing which I do not understand, the NVRAM address zoning starts at 0x04000000 which is totally different than address 0x50009 used by VISA-GPIB command https://www.eevblog.com/forum/repair/gpib-usb-control-between-macbook-air-(macintosh)-and-tds540c/msg2840286/#msg2840286
Another question, do you know what is the equivalent Visa-GPIB inline command of "libManagerWordAt()" ?
Albert
Offline ragge
« Reply #26 on: January 02, 2020, 03:55:00 pm »
Hi Albert,
No, I sadly have no idea how you get that information. It may have something to do with console access, which I still have not fixed.
I you find out, please post it here!
Regards,
Ragnar
  • Radio DSP Plasma
    • Tantratron
« Reply #27 on: January 02, 2020, 05:04:54 pm »
Hi Ragnar,
I guess we need to find out in EEVblog forum or tekforum the member (genius) who found that method, these specific Visa-GPIB console of first "PASSWORD PITBULL" then followed by "WORDCONSTANT:ATPUT 327689,1" to enable the FFT.
Another way to understand how this works, at what address the PITBULL password is captured by the TDS then the address mechanism for the options https://www.eevblog.com/forum/testgear/tds420-with-lost-options/msg889412/#msg889412 and https://www.eevblog.com/forum/testgear/tds420-with-lost-options/msg889461/#msg889461
Maybe worth deepen the C coding information provided by Andy Watson or maybe he could join this thread
Albert
« Last Edit: January 02, 2020, 05:07:47 pm by Tantratron »
  • Radio DSP Plasma
    • Tantratron
« Reply #28 on: January 04, 2020, 04:29:17 am »
For tekfwtool, you don't need anything but the command line.
You need to have Xcode installed to have the compiler and the other development tools (if you don't want to install some other tool chain for some reason).
You seem to have already installed the NI libraries for 488, which is what it will use in this case.
I think this should pretty much work:
# get a copy of the kit from github
git clone [url]https://github.com/ragges/tektools.git[/url]
# go to the tekfwtool directory
cd tektools/tekfwtool
Then with your favourite editor, in tekfwtool.c, to include the NI headers instead, replace
    #include <gpib/ib.h>
with
    #include <ni4882.h>
Then it SEEMS this is the NI recommended way to compile the program (not very MacOS-/NextSTEP-ish, but...):
cc -g -fsigned-char tekfwtool.c /Library/Frameworks/NI4882.framework/Resources/ni4882.o -framework CoreFoundation -I/Library/Frameworks/NI4882.framework/Headers -o tekfwtool
You should now have a working program, check that it runs with e.g.:
./tekfwtool --help
For those very few who have a Macintosh (Mac OS X) with GPIB-USB-HS National Instruments interface, I confirm the tekfwtool compiles and runs OK when communicating with my TDS540C (see attached screen shot of reading the 1486 NVSRAM).
For the moment, it is not clear if this C version works for erasing then flashing the firmware on all TDS 5xx/6xx/7xx/8xx so extra care and verification are needed due to different C versions on the internet https://www.eevblog.com/forum/repair/tekfwtool-for-tds540c-firmware-upgrade/msg2855192/#msg2855192
If there is some interest, we could update the complete set.
Albert
« Last Edit: January 04, 2020, 04:44:14 am by Tantratron »
Offline Andy Watson
« Reply #29 on: January 10, 2020, 07:42:56 pm »
I don't think I can add anything to what's already been said. All the information I have has been gleened from the web. There used to be a Tektronix forum that had useful information available - I don't know if it's still active.  https://forum.tek.com/index.php?sid=0a9094a730452c52c480a67c30d1300f  Looks like it is still active, but I think you have to register to get at the manuals.
