Author Topic: ds216+ H255L  (Read 720 times)
Offline GODTopic starter
ds216+ H255L
« on: November 04, 2019, 11:10:01 am »
hey guys what is the h255L component is a active or passive type. how do i tell if its it active or not. Also is the component a crystal or a oscillator? This is in a synology ds216+ nas
 :horse:
Offline coromonadalix
Re: ds216+ H255L
« Reply #1 on: November 04, 2019, 11:19:30 am »
Its a crystal oscillator with its 2 associated capacitors, normally you can test it with a scope on x10 impedance, youlll be able to see its frequency output on some pins
One of the two round pads near the caps will show you the frequency ??
The ic is an Intel I211  Lan controller, the datasheet says 25 mhz clock
« Last Edit: November 04, 2019, 11:33:07 am by coromonadalix »
Re: ds216+ H255L
« Reply #2 on: November 05, 2019, 10:11:55 am »
thanks for replies currently don't have oscilloscope currently. I did get the fact it is a 25mhz but is a active or passthrough model?
