Picked up this SRS DS345 for a reasonable price with the following self test error on boot up...
The manual has a listing of self test errors, with helpful but vague areas to check.
It would be better to include "check surrounding circuitry as well."
After much troubleshooting I found the output of the DAC was a bizarre looking signal. Two and a half times the expected frequency and DC offset on both diff. outputs.
Checking all the digital inputs from the ECL translator chips (MC10124) I found that pin 14 (MSB) on the DAC had no input. That led back to U504D. Changing U504D solved the issue. Now passes all tests.
Hope this can help someone spend less time troubleshooting.
