Author Topic: DSE Q1760 Box of bits  (Read 2961 times)
Offline electrogeekTopic starter
« on: March 20, 2016, 04:55:25 am »
Well, as tails of woe can go I find myself with a freshly thrown out DSE Q1760 Bench top power supply. What could possible be so wrong I thinks to myself, here will be the catalog of just what I find. and with some luck, acquire a useful little power supply.
it arrived in my hands in the condition shown, so I am expecting a bit of a challenge. I have found a schematic
Here it is.
already.
Any thoughts where I should start looking? usually I would start by plugging it in a verifying there is in fact a fault, but I suspect this one is a bit past that. it looks like from the bits that came with it someone has already replaced the bridge which makes me a bit nervous about what is lurking.
Cheers
Re: DSE Q1760 Box of bits
« Reply #1 on: March 20, 2016, 05:30:20 am »
I guess this isn't factory fresh...
« Reply #2 on: March 20, 2016, 06:16:45 am »
Doubt that had anything to do with it's failure, but I guess it'll need replacing, and probably if one is bad, they all are....
« Reply #3 on: March 20, 2016, 06:29:19 am »
The bodge is strong with this one. I guess you have to power the fan from somewhere...
« Reply #4 on: March 21, 2016, 05:08:33 am »
Its alive! now to put it all back together and see if it regulates. for those playing at home the fault(s) were as follows:
1x short bridge rectifier (DA1) (I'd love people thoughts on how that might come to fail)
4x tracks burnt off pcb, V1-RLY1, V2-RLY1, not well labeled, but what appears to be V3-C33 and lastly RLY1-C24.
Offline iampoor
« Reply #5 on: March 21, 2016, 08:26:16 am »
How hot does the Bridge Rectifier get?
Is the PCB made from the same material that is use in cheap consumer electronics? (FR1?)
« Reply #6 on: March 21, 2016, 10:14:04 am »
They may have been running the bridge a bit hot, the fan kicks on when the heat sink the bridge is on hits 60 degrees. And regarding board material, yes it appears to be fr1.
Offline Shock
« Reply #7 on: March 21, 2016, 12:47:09 pm »
Filter capacitor.
