Author Topic: Fluke 8808A Pantalla con poco Brillo  (Read 731 times)
Offline kekoTopic starter
  • Country: cl
« on: December 10, 2021, 02:54:42 pm »
Hola Amigos.
Compre un Fluke 8808A por Ebay - USA de segunda mano, fue enviado a Chile muy bien embalado, lo estoy probando y está funcionando bien, pero la pantalla tiene menos brillo que la del Fluke 45, además cuando mido Diodos no emite un sonido como el Fluke 45.
¿Amigos es Normal lo que ocurre con la pantalla con poco brillo y la medición de diodos sin sonido?, ¿es posible configurar el brillo de la pantalla y activar el sonido al medir Diodos?
Agradezco su ayuda y orientación con mi Fluke 8808A
Offline tunk
  • Country: no
Re: Fluke 8808A Pantalla con poco Brillo
« Reply #1 on: December 10, 2021, 03:05:05 pm »
English please - maybe you could use google translate?
The following users thanked this post: keko
  • Country: cl
« Reply #2 on: December 10, 2021, 03:09:03 pm »
Thank you very much for your reply ... Excuse my English!
Hi friends.
I bought a second hand Fluke 8808A by Ebay - USA, it was sent to Chile very well packaged, I am testing it and it is working well, but the screen has less brightness than the Fluke 45, also when I measure Diodes it does not emit a sound like the one on the Fluke 45.
Friends, is it normal what happens with the screen with low brightness and the diode measurement without sound? Is it possible to set the screen brightness and activate the sound when measuring diodes?
I appreciate your help and guidance with my Fluke 8808A
Online gamalot
  • Correct my English
    • Youtube
« Reply #3 on: December 10, 2021, 03:18:26 pm »
Yes.
No.
  • Country: cl
« Reply #4 on: December 10, 2021, 03:31:17 pm »
Thank you very much Friend for your answer.
I've had the Fluke 45 for a long time, it's an excellent piece of equipment. My New Fluke 8808A arrived and I am learning its functions.
Greetings from Chile
