Author Topic: DSO1511e Plus Firmware Backup Flash Dump  (Read 448 times)
Offline rtek1000Topic starter
  • Country: br
« on: June 16, 2022, 06:14:38 am »
Hello,
Could someone please send a copy of the contents of the Flash memory of the DSO1511e?
I bricked my DSO1511e but was able to recover it with help from a friend after compiling the bootloader and combining the original firmware, but the boot image is still missing.
I could try using the Ghidra program to try to locate some image stored in the firmware, but I believe it's easier to back up, and I also believe it's good for users to know how to do that backup.
The procedure for backing up Flash should be as follows:
1- Create an SD Card with the USB Port Access Tool
2- Insert the SD card into the slot on the DSO1511e board
3- Press and hold the DSO1511e power button
4- Connect the USB cable to the computer and the DSO1511e
5- Read Flash content
Reference of commands and procedures I left described in this repository:
https://github.com/rtek1000/DSO1511e_Plus_Unbrick
Thank you!
